I’ve been struggling all night, working with ChatGPT, to resolve an SSL configuration issue on my Home Assistant setup hosted on a Raspberry Pi 3 (rpi3-64). Here are the details:
- HA accessible locally on a private IP (Port 8123).
- Domain set for remote access (domain withheld for privacy).
- Router port forwarding configured from WAN port 8443 to HA’s LAN port 8123.
- Utilizing Let’s Encrypt for SSL, with certificates set up in HA.
- Employing “NGINX Home Assistant SSL proxy” add-on in HA, with HTTP port default and HTTPS port set to 8443.
However, I’m unable to access HA remotely over HTTPS, encountering “ERR_SSL_PROTOCOL_ERROR” in my browser, and HA logs present multiple timeout errors and “BadStatusLine: 400” related to aiohttp.server. I’m looking for advice on potential SSL handling issues or NGINX reverse proxy misconfigurations.
Here are the http settings in configuration.yaml:
http:
ip_ban_enabled: false
login_attempts_threshold: 100
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
- 127.0.0.1
HA System Versions:
Core: 2023.12.3
Supervisor: 2023.12.0
Operating System: 11.2
Frontend: 20231208.2
Appreciate any help or suggestions!
