ElVit
June 6, 2024, 11:50am
1
Hi community,
I have found somewhere on reddit (can not remember the exact link) a very nice person card.
So its actually not my idea, but I couldn’t find it here in the community forum, so I will show it here.
After some modifications my card looks like this:
It uses geoapify to get a static backround image of your current device_tracker position.
So you will need an geoapify account.
The free plan allows you 3000 requests per day.
For me its more than enough, but if you need more you have to choose a different plan and pay for it.
Additionally you will need some integrations frome the HACS store:
Here is the Code:
type: custom:stack-in-card
card_mod:
style: |
ha-card {
background: url('https://maps.geoapify.com/v1/staticmap?style=osm-bright&width=600&height=230¢er=lonlat:{{ state_attr('device_tracker.MY_IPHONE', 'longitude') }},{{ state_attr('device_tracker.MY_IPHONE', 'latitude') }}&zoom=14.0&marker=lonlat:{{ state_attr('device_tracker.MY_IPHONE', 'longitude') }},{{ state_attr('device_tracker.MY_IPHONE', 'latitude') }};type:material;color:%23ff3421;icontype:awesome&scaleFactor=2&apiKey=YOUR_API_KEY');
background-size: cover;
background-blend-mode: overlay;
background-color: rgba(var(--rgb-card-background-color), 0.5);
cards:
entity: person.MY_PERSON
primary: MY_PERSON
secondary: >-
{{ iif(states(entity) == 'not_home', 'away', states(entity)) | title }} |
{{ states('sensor.MY_IPHONE_geocoded_location') }}
picture: '{{ state_attr(entity, ''entity_picture'') }}'
badge_icon: >-
{% set zone = iif(states(entity) == 'not_home', 'away', states(entity)) %}
{%- if 'home' in zone.lower() -%}
mdi:home
{%- elif zone == 'MY_WORK' -%}
mdi:office-building
{%- else -%}
mdi:home-export-outline
{%- endif -%}
badge_color: >-
%} {%- if 'home' in zone.lower() -%}
green
blue
{%- else -%}
red
{%- endif -%}
fill_container: true
multiline_secondary: false
layout: horizontal
tap_action:
action: more-info
card_mod:
style: |
:host {
height: 70px;
--mush-icon-size: 60px;
--secondary-text-color: var(--primary-text-color);
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: sensor.MY_IPHONE_steps
- type: entity
entity: sensor.MY_IPHONE_battery_state
card_mod:
style: |
ha-card {
--chip-box-shadow: 0px 0px 0px 0px;
--chip-background: none;
To make it work you have to replace the following text:
YOUR_API_KEY → This is your API Key from Geoapify
MY_IPHONE → This is the name of your device_tracker. I used the device_tracker from the mobile_app integration
MY_PERSON → This is the name of your person entity
MY_WORK → This is the zone where you work (optional)
supperka
(Supperka)
June 6, 2024, 12:56pm
2
Awesome thank you,
I’m just little tweak
secondary: >-
Text was so long to show on card.
So my looks
secondary: >-
ul. {{state_attr('sensor.pogo5x_geocoded_location', 'thoroughfare') }}
čís.{{ state_attr('sensor.pogo5x_geocoded_location', 'premises') }} PSČ {{
state_attr('sensor.pogo5x_geocoded_location', 'postal_code') }}
ElVit
June 6, 2024, 2:50pm
3
Thank you for your improvment .
I will add it also into my cards.
Unfortunatelly I can not see the attribute premises, maybe because I am using an iPhone?
But for me the attributes Name, Postal Code and Sub Locality worked quit well.
supperka
(Supperka)
June 6, 2024, 2:51pm
4
Hello again , how can I change color text or opacity?
on computer is text barely visible.
ElVit
June 6, 2024, 2:58pm
5
I think its the 0.5 in line 8.
supperka
(Supperka)
June 6, 2024, 3:10pm
6
that’s for background color and opacity.
ElVit
June 12, 2024, 12:38pm
8
Oh so I misunderstood your question.
In my opinion it makes more sense to change the opacity of the background image than the text color opacity.
And also I don’t know how to change the text opacity, sorry.
But you can maybe change the the map style.
Please see the Geoapify Docs for more infos.
Currently I use osm-bright .
Simply change this to a darker style e.g. dark-matter-yellow-roads if you are using a bright text color.
ElVit
June 12, 2024, 12:55pm
9
One more improvment from my side:
It is also possible to change the color or icon of the map marker depending on your location.
Simply change the background url for this:
background: url('https://maps.geoapify.com/v1/staticmap?style=osm-bright&width=600&height=230¢er=lonlat:{{ state_attr('device_tracker.MY_IPHONE', 'longitude') }},{{ state_attr('device_tracker.MY_IPHONE', 'latitude') }}&zoom=14.0&marker=lonlat:{{ state_attr('device_tracker.MY_IPHONE', 'longitude') }},{{ state_attr('device_tracker.MY_IPHONE', 'latitude') }};type:material;{{ iif(is_state('person.MY_PERSON', 'home'), 'color:green;icon:home;', iif(is_state('person.MY_PERSON', 'MY_WORK'), 'color:blue;icon:building;', 'color:red;')) }}icontype:awesome&scaleFactor=2&apiKey=YOUR_API_KEY');
it wont work for me…whats my fault?
card_mod:
style: |
ha-card {
background: url('https://maps.geoapify.com/v1/staticmap?style=osm-bright&width=600&height=230¢er=lonlat:{{ state_attr('device_tracker.s24_ultra_marko', 'longitude') }},{{ state_attr('device_tracker.s24_ultra_marko', 'latitude') }}&zoom=14.0&marker=lonlat:{{ state_attr('device_tracker.s24_ultra_marko', 'longitude') }},{{ state_attr('device_tracker.s24_ultra_marko', 'latitude') }};type:material;color:%23ff3421;icontype:awesome&scaleFactor=2&apiKey=);
cards:
entity: person.marko
primary: MY_PERSON
secondary: >-
badge_icon: >-
mdi:home
mdi:office-building
{%- else -%}
{%- endif -%}
badge_color: >-
green
blue
{%- else -%}
red
{%- endif -%}
layout: horizontal
tap_action:
action: more-info
card_mod:
style: |
:host {
height: 70px;
chips:
- type: entity
- type: entity
card_mod:
style: |
ha-card {
Zenia
(Yevgeniy)
June 13, 2024, 9:18pm
11
Thank you for this card. I modify mine a little bit using your suggestion about background
My code:
mode: vertical
card_mod:
style: |
ha-card {
border: none !important;
# background: none !important;
--vertical-stack-card-gap: 10px;
background: url('https://maps.geoapify.com/v1/staticmap?style=dark-matter-yellow-roads&width=600&height=230¢er=lonlat:{{ state_attr('device_tracker.sm_s918u', 'longitude') }},{{ state_attr('device_tracker.sm_s918u', 'latitude') }}&zoom=14.0&marker=lonlat:{{ state_attr('device_tracker.sm_s918u', 'longitude') }},{{ state_attr('device_tracker.sm_s918u', 'latitude') }};type:material;color:%23ff3421;icontype:awesome&scaleFactor=2&apiKey=API KEY');
background-size: 135%;
cards:
- type: custom:stack-in-card
mode: horizontal
card_mod:
style: |
ha-card {
cards:
- type: custom:mushroom-person-card
entity: person.yevgeniy
layout: vertical
icon_type: entity-picture
primary_info: state
secondary_info: false
card_mod:
style:
mushroom-shape-avatar$: |
.picture {
display: flex;
border-radius: 50%;
{% if states(config.entity) == 'home' %}
animation: pinggreen 6s infinite;
{% else %}
animation: pingred 6s infinite;
{% endif %}
@keyframes pinggreen {
0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-green), 0.9);}
100% {box-shadow: 0 0 5px 15px transparent;}
@keyframes pingred {
0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-red), 0.9);}
ha-card {
margin-left: -50px !important;
mode: vertical
card_mod:
style: |
ha-card {
margin-left: -55px !important;
cards:
primary: >-
{%- if is_state('sensor.sm_s918u_battery_state', 'charging') %}
Charging 🔌
{%- elif is_state('sensor.sm_s918u_battery_state', 'discharging')
Discharging 🙃
{% else %}
Full 💯
{% endif %}
secondary: Battery {{ states('sensor.sm_s918u_battery_level') }}%
entity: sensor.sm_s918u_battery_state
icon: |2
{% set bl = states('sensor.sm_s918u_battery_level') | int %}
{% if bl < 10 %} mdi:battery-outline
{% elif bl < 20 %} mdi:battery-10
{% elif bl < 30 %} mdi:battery-20
{% elif bl < 40 %} mdi:battery-30
{% elif bl < 50 %} mdi:battery-40
{% elif bl < 60 %} mdi:battery-50
{% elif bl < 70 %} mdi:battery-60
{% elif bl < 80 %} mdi:battery-70
{% elif bl < 90 %} mdi:battery-80
{% elif bl < 100 %} mdi:battery-90
{% elif bl == 100 %} mdi:battery
{% else %} mdi:battery-unknown
{% endif %}
icon_color: |2-
{% if bl < 10 %} red
{% elif bl < 20 %} red
{% elif bl < 30 %} red
{% elif bl < 40 %} orange
{% elif bl < 50 %} orange
{% elif bl < 60 %} green
{% elif bl < 70 %} green
{% elif bl < 80 %} green
{% elif bl < 90 %} green
{% elif bl < 100 %} green
{% elif bl == 100 %} green
{% else %} grey
{% endif %}
card_mod:
style: |
ha-card {
justify-content: center;
--chip-icon-size: 24px;
--chip-height: 54px;
--chip-with:
width: var(--chip-height) !important;
border-radius: 50% !important;
alignment: center
chips:
- type: entity
card_mod:
style: |
ha-card {
font-size: 30px !important;
entity: sensor.sm_s918u_geocoded_location
icon: mdi:google-maps
use_entity_picture: false
card_mod:
style: |
ha-card {
margin-left: -23px !important;
alignment: center
Krona
June 15, 2024, 3:24am
12
Fantastic card! But why is my map not as dark as yours? The text is barely visible
Zenia
(Yevgeniy)
June 15, 2024, 10:29am
13
check this part of url line
Thank you for compliment
Krona
June 15, 2024, 1:07pm
14
Problem is that’s another map. I want the original but dark one as elVit and supperka shows in their posts. Not sure where i fail, i copied the same code as in the first post
Zenia
(Yevgeniy)
June 15, 2024, 2:14pm
15
Try to change font color and opacity
Template Card Sections are split:
Main Icon Styling
You can style the main icon like this:
Change the icon type/mdi.
[image]
Of course for the template card you could also just use the visual editor…
card_mod:
style: |
ha-state-icon {
--card-mod-icon: mdi:mushroom;
Change the icon color.
[image]
card_mod:
style: |
ha-state-icon {
color: orange;
Change icon size.
[image]
car…
david1
(David)
June 17, 2024, 2:00am
16
Nice! for the step info, does the iphone have to be on the same network as Home-assistant? or can it pull it from the cloud
Awesome looking card!
Unfortunately I don’t see the possibility to create an API on the website of Geoapify (via <Geoapify / My Projects > ).
Hopefully their support can help me out, so I can create this great Person Card!
ElVit
June 20, 2024, 4:57pm
18
Maybe this will help you:
text-shadow: 0px 0px 5px white;
Add this code simply in the ha-card context where the background image is set.
For alternative configurations of text-shadow see this link .
Freeman59
(Julien Leconte)
July 26, 2024, 7:55pm
19
Hello !
Thanks for sharing this amazing view Also I have 2 questions
First : As I’m using a white dashboard, I can see line that separate first column of the second one
First is logo of the person with Zone | Geocoded location where the second one is custom:mushroom-chips-card
Could you tell me how to delete these line ?
Also, How can I get a higher view of the card ? I don’t really know how to expand high of it.
Thanks !
ElVit
July 28, 2024, 8:08am
20
I can also see some lines but only while the card is loading. Then they are gone. I think the card_mod part should remove these lines.
Maybe you have a custom theme which adds these lines back? Or your card_mod plugin is maybe not working?
And to make this card bigger I simply added an empty markdown card like so:
- type: markdown
content: ' '
card_mod:
style: |
:host {
height: 40px;
This is really great, thank you.
One question: I copied your code & input my data, everything works except the badge doesn’t update depending on location. It only shows the mdi:home-export-outline and is red all the time. What might be causing this?
card_mod:
style: |
ha-card {
background: url('https://maps.geoapify.com/v1/staticmap?style=dark-matter-purple-roads&width=600&height=240¢er=lonlat:{{ state_attr('device_tracker.pixel_8_pro_g', 'longitude') }},{{ state_attr('device_tracker.pixel_8_pro_g', 'latitude') }}&zoom=14.0&marker=lonlat:{{ state_attr('device_tracker.pixel_8_pro_g', 'longitude') }},{{ state_attr('device_tracker.pixel_8_pro_g', 'latitude') }};type:material;color:%23ff3421;icontype:awesome&scaleFactor=2&apiKey=################');
cards:
entity: person.giuseppebaldi
primary: Giuseppe
secondary: >-
{{ states('sensor.pixel_8_pro_g_geocoded_location') }}
picture: "{{ state_attr(entity, 'entity_picture') }}"
badge_icon: >-
mdi:home
{%- elif zone == 'zone.work' -%}
mdi:office-building
{%- else -%}
{%- endif -%}
badge_color: >-
green
blue
{%- else -%}
red
{%- endif -%}
layout: horizontal
tap_action:
action: more-info
card_mod:
style: |
:host {
height: 70px;
--mush-icon-size: 75px;
--primary-text-color: #e0e0e0;
chips:
- type: entity
entity: sensor.pixel_8_pro_g_battery_level
- type: entity
entity: sensor.pixel_8_pro_g_battery_state
card_mod:
style: |
ha-card {
--color: #D3D3D3;
