Just updated to 0.88 and tried out the person component. Seems to work well (pretty much like a group with the device trackers?). However, both my device trackers have an image, but neither show once I show the person with those two device trackers.
Can we force this, or simply use the latest update source from a person?
I understand that just the basic functionality was introduced at this time.
From Release Notes: “This release does basic device tracker state merging, which will be evolved in the future. Device trackers merging their own states will be phased out in favor of persons.”
It worked fine for me. I changed it in the customization section in the ui. Added entity_picture at the bottom and added a link for each person to a picture, like this.
anyone managed to use local files as entity_picture? The entry I used for device_tracker doesn’t work for Persons: /local/profile_square_small.png , which is a file inside config/www
Yes it works with entity_picture and double quoted local files.
But Im using the person as a badge in lovelace and it doesn’t show the state anymore only picture. Other device tracker badges includes a small state indicator in the lower part of the circle but the person badge only shows as the picture.
Patrik - (weird to spell my name without a c)
I too am trying to figure this out.
Here is a snip of my customize ui from the config menu.
I am running the latest hassio on a ubuntu 18.04 desktop image on intel nuc.
One of the weird things that happens when i put the data in as you suggest above (screenshot one) is that when I refresh to have changes to effect and look at the entry (cos no piccy shows) I see the hassio has added extra backslashes and quotation marks in the json formatting?? (screenshot two)
I am obviously doing something quite wrong - and knowing me most likely simple.
One question - when going into customize entity - I have created an other field where I put all this. Is that right?
Patrick
