I’ve been a user of duckdns and the set-up worked perfectly. Due to security restrictions at work duckdns is restricted so I’ve registered my own domain name. I’ve removed SSH from my config. But I can’t access HA remotely using my domain which points to my public address. I’ve tried http and https, with and without port 8123
The local IP address is ok. I’m struggling to understand what I need to do to set it up. Your help would be appreciated.
Thank you
