I have a “Pantech WH2900” personal weather station, which seems like it’s a white-labelled variant of a Ambient WS-2902 - https://www.ambientweather.com/amws2902.html
I’ve been struggling to get the data integrated into Home Assistant using weewx and intercept drivers, until I decided to use Node-Red.
I created a http endpoint in Node-Red which receives the data using the ecowitt protocol, configured like this in the app…
Then I need to do some unit conversions, and output to home assistant sensors.
I’ve obviously tested only with my PWS, but I assume the same flow should work with any PWS that can use the ecowitt protocol to send data to a custom server.
Here is the node-red code if anyone wants to give it a go…
[{"id":"c2802b40.2b07c8","type":"tab","label":"Weather Station","disabled":false,"info":""},{"id":"4a568252.a4270c","type":"http response","z":"c2802b40.2b07c8","name":"","statusCode":"","headers":{},"x":130,"y":260,"wires":[]},{"id":"188ceb1c.321dc5","type":"http in","z":"c2802b40.2b07c8","name":"Incoming Weather Data","url":"/weather","method":"post","upload":false,"swaggerDoc":"","x":180,"y":360,"wires":[["4a568252.a4270c","e197a1a.a0dc56","df151c2c.c6ecc","f97d2572.9a97b8","137d29d3.4f6446","97e472bf.f372a","246154bc.fd06fc","65c3eecd.8cf2e","dbf42355.57edd","ccfd1178.f17dd","c00f531a.63299"]]},{"id":"e197a1a.a0dc56","type":"ha-entity","z":"c2802b40.2b07c8","name":"Wind Direction","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Wind Direction"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:compass"},{"property":"unit_of_measurement","value":"°"}],"state":"payload.winddir","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":440,"y":40,"wires":[[]]},{"id":"df151c2c.c6ecc","type":"ha-entity","z":"c2802b40.2b07c8","name":"Humidity","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Weather Station Humidity"},{"property":"device_class","value":"humidity"},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"%"}],"state":"payload.humidity","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":420,"y":100,"wires":[[]]},{"id":"f97d2572.9a97b8","type":"unit-converter","z":"c2802b40.2b07c8","category":"temperature","inputUnit":"F","outputUnit":"C","inputField":"payload.tempf","outputField":"payload","inputFieldType":"msg","outputFieldType":"msg","name":"F to C","x":410,"y":160,"wires":[["173a30c1.b5b3bf"]]},{"id":"8432e3bb.fb241","type":"ha-entity","z":"c2802b40.2b07c8","name":"Temperature","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Weather Station Temperature"},{"property":"device_class","value":"temperature"},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"°C"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":850,"y":160,"wires":[[]]},{"id":"137d29d3.4f6446","type":"unit-converter","z":"c2802b40.2b07c8","category":"speed","inputUnit":"m/h","outputUnit":"km/h","inputField":"payload.windspeedmph","outputField":"payload","inputFieldType":"msg","outputFieldType":"msg","name":"mph to kmph","x":440,"y":220,"wires":[["9d95ca4c.03a6e8"]]},{"id":"b969287b.198cb8","type":"ha-entity","z":"c2802b40.2b07c8","name":"Wind Speed","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Wind Speed"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weather-windy"},{"property":"unit_of_measurement","value":"km/h"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":850,"y":220,"wires":[[]]},{"id":"97e472bf.f372a","type":"unit-converter","z":"c2802b40.2b07c8","category":"speed","inputUnit":"m/h","outputUnit":"km/h","inputField":"payload.windgustmph","outputField":"payload","inputFieldType":"msg","outputFieldType":"msg","name":"mph to kmph","x":440,"y":280,"wires":[["e8e92d12.8e85e"]]},{"id":"777c4951.f99c88","type":"ha-entity","z":"c2802b40.2b07c8","name":"Wind Gust","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Wind Gust"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weather-tornado"},{"property":"unit_of_measurement","value":"km/h"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":850,"y":280,"wires":[[]]},{"id":"246154bc.fd06fc","type":"unit-converter","z":"c2802b40.2b07c8","category":"length","inputUnit":"in","outputUnit":"mm","inputField":"payload.rainratein","outputField":"payload","inputFieldType":"msg","outputFieldType":"msg","name":"\" to mm","x":420,"y":340,"wires":[["3efd90f4.3e62b","114566c9.6230b9"]]},{"id":"b6951c41.319fe","type":"ha-entity","z":"c2802b40.2b07c8","name":"Rain Rate","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Rain Rate"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weather-rainy"},{"property":"unit_of_measurement","value":"mm/hr"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":840,"y":340,"wires":[[]]},{"id":"65c3eecd.8cf2e","type":"unit-converter","z":"c2802b40.2b07c8","category":"length","inputUnit":"in","outputUnit":"mm","inputField":"payload.dailyrainin","outputField":"payload","inputFieldType":"msg","outputFieldType":"msg","name":"\" to mm","x":420,"y":460,"wires":[["5438955b.d50c0c"]]},{"id":"3922801c.04aea","type":"ha-entity","z":"c2802b40.2b07c8","name":"Rain Accumulation","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Rain Accumulation"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:cup-water"},{"property":"unit_of_measurement","value":"mm"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":870,"y":460,"wires":[[]]},{"id":"b22429c6.87f798","type":"ha-entity","z":"c2802b40.2b07c8","name":"Raining","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"binary_sensor","config":[{"property":"name","value":"Raining"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weather-pouring"},{"property":"unit_of_measurement","value":""}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":840,"y":400,"wires":[[]]},{"id":"dbf42355.57edd","type":"function","z":"c2802b40.2b07c8","name":"Pressure","func":"var baromabsin = Number(msg.payload.baromabsin)\nvar pressure = baromabsin * 33.863886666667\n\nmsg.payload = pressure.toFixed(1)\nreturn msg;","outputs":1,"noerr":0,"x":420,"y":540,"wires":[["80930617.f29d98"]]},{"id":"80930617.f29d98","type":"ha-entity","z":"c2802b40.2b07c8","name":"Atmospheric Pressure","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Atmospheric Pressure"},{"property":"device_class","value":"pressure"},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"hPa"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":660,"y":540,"wires":[[]]},{"id":"ccfd1178.f17dd","type":"function","z":"c2802b40.2b07c8","name":"Solar Radiation","func":"var x = Number(msg.payload.solarradiation)\nmsg.payload = x.toFixed(1)\nreturn msg;","outputs":1,"noerr":0,"x":440,"y":620,"wires":[["99944557.d4dbc8"]]},{"id":"99944557.d4dbc8","type":"ha-entity","z":"c2802b40.2b07c8","name":"Solar Radiation","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Solar Radiation"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:white-balance-sunny"},{"property":"unit_of_measurement","value":"W/m²"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":640,"y":620,"wires":[[]]},{"id":"c00f531a.63299","type":"ha-entity","z":"c2802b40.2b07c8","name":"UV","server":"a23a4d01.eeb32","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"UV"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:weather-sunny-alert"},{"property":"unit_of_measurement","value":""}],"state":"payload.uv","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":410,"y":700,"wires":[[]]},{"id":"3efd90f4.3e62b","type":"function","z":"c2802b40.2b07c8","name":"raining?","func":"var x = Number(msg.payload)\n\nif (x > 0) {\n msg.payload = true;\n} else {\n msg.payload = false;\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":620,"y":400,"wires":[["b22429c6.87f798"]]},{"id":"173a30c1.b5b3bf","type":"function","z":"c2802b40.2b07c8","name":"Single Decimal Place","func":"var x = Number(msg.payload)\n\nmsg.payload = x.toFixed(1)\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":160,"wires":[["8432e3bb.fb241"]]},{"id":"9d95ca4c.03a6e8","type":"function","z":"c2802b40.2b07c8","name":"Single Decimal Place","func":"var x = Number(msg.payload)\n\nmsg.payload = x.toFixed(1)\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":220,"wires":[["b969287b.198cb8"]]},{"id":"e8e92d12.8e85e","type":"function","z":"c2802b40.2b07c8","name":"Single Decimal Place","func":"var x = Number(msg.payload)\n\nmsg.payload = x.toFixed(1)\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":280,"wires":[["777c4951.f99c88"]]},{"id":"114566c9.6230b9","type":"function","z":"c2802b40.2b07c8","name":"Single Decimal Place","func":"var x = Number(msg.payload)\n\nmsg.payload = x.toFixed(1)\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":340,"wires":[["b6951c41.319fe"]]},{"id":"5438955b.d50c0c","type":"function","z":"c2802b40.2b07c8","name":"Single Decimal Place","func":"var x = Number(msg.payload)\n\nmsg.payload = x.toFixed(1)\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":460,"wires":[["3922801c.04aea"]]},{"id":"a23a4d01.eeb32","type":"server","z":"","name":"Home Assistant"}]
