Is it possible to rebrand HA as another name so I could name it , "(last name)'s Automation. I just didn’t know if a way was already built to do this. Change the name of the software and the logo?
Mostly? I mean don’t ask me how because I’m not a frontend person. But if you make a custom plugin you have pretty much free reign to modify the UI. I’d start by looking at themes in HACS and then seeing if you can adapt what they’re doing to meet your needs.
If that’s not enough control for you then perhaps take a look at card mod and kiosk mode to see how those give you even greater control over the dashboard and surrounding frame. See if you can adapt what they’re doing to your needs.
That being said I’m not really aware of any way to customize the login screen. I’m not sure that’s possible currently.
Also if you were looking for an easy way that didn’t involve any coding then the answer is no. The only solutions involve coding your own theme or plugin. HA isn’t really designed for the multi-tenant and PaaS use cases that usually warrant these kinds of features.
