Hi everyone,
I recently came across the following device: https://www.artificialsky.tech/. I don’t need to mention that I bought it straight away because: i) my bathroom lacks a window (therefore natural light); ii) in the office of the company I used to work for they did have several original Coelux products and the result stunned me.
What is it
It is a smart light that simulates incredibly well a window in your ceiling. It is “inspired” (aka: copied) from the famous Italian Coelux that retails in the order of magnitude of 10k€.
It is made in China and the quality is extremely good. The effect is incredible: it really looks like you have a window in your ceiling; the pictures on the website don’t lie! It retails for a fraction of the price of Coelux and on top of that it has WiFi and Bluetooth mesh network.
What I want to achieve
t is very “simple”: I want to integrate it in Home Assistant. Through this post I will keep you updated on my progress in trying to reverse engineer it and integrate it in Home Assistant.
My understanding of how it works
It is comprised of three devices:
- the Skylight: the light itself that is WiFi and Bluetooth (mesh network) enabled, and that can be controlled from your smartphone via Bluetooth;
- the Smart Pad: (or whatever it is called) a small wall-mounted display (I think is around 4") through which you can control the Skylight itself (and all its settings, hour of the day simulation, change of color, change of temperature) and control two loads that can be connected directly to the Smart Pad;
- your smartphone: iOS or Android, through which you can control the Skylight, the Smart Pad and enable the communication between the two devices.
The configuration process is as follows
- Connect the Skylight to your smartphone by pairing it via bluetooth;
- Configure the wifi on the Skylight through your smartphone;
- Connect the Smart Pad to your smartphone through bluetooth;
- Configure the wifi on the Smart Pad (directly on the screen).
What are wifi and bluetooth used for:
So far to my understanding, all the communication between the three devices is performed through the bluetooth mesh network, with the smartphone being the central node which connects the devices among themselves.
WiFi I believe so far that it is used only for setting the time on the devices and downloading firmware updates.
What I have done so far
I am currently at step number 1: reverse engineering the communication protocol of the Smart Pad and the Skylight.
Analysis of communication over WiFi:
I have analyzed the packets exchanged from the SmartPad from the Skylight using Wireshark. My conclusions are the following:
- Smartpad
- There is no data exchanged over WiFi between the Skylight and the Smart Pad
- I could not sniff anything coming from or going to the Smart Pad, not even when forcing a firmware upgrade
- Skylight
- There might be data exchanged between the smartphone and the Skylight but I’m not sure
- When I turn on/off the Skylight or I change the settings of the Skylight (e.g., change brightness) from my smartphone there are packets sent from the Skylight (to god knows where)
- Here is an example of the packets transmitted from the Skylight when I turn it on and off:
No. Time Source Destination Protocol Length Info
645 56.726440129 192.168.1.160 255.255.255.255 UDP 61 9988 → 8899 Len=19
Frame 645: 61 bytes on wire (488 bits), 61 bytes captured (488 bits) on interface wlp0s20f3, id 0
Ethernet II, Src: BeijingW_80:4f:21 (28:6d:cd:80:4f:21), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Internet Protocol Version 4, Src: 192.168.1.160, Dst: 255.255.255.255
User Datagram Protocol, Src Port: 9988, Dst Port: 8899
Data (19 bytes)
0000 aa 55 00 64 b0 53 17 00 00 00 0e 00 03 03 01 01 .U.d.S..........
0010 01 ba 6e ..n
Data: aa550064b053170000000e000303010101ba6e
[Length: 19]
661 58.254181153 192.168.1.160 255.255.255.255 UDP 68 9988 → 8899 Len=26
Frame 661: 68 bytes on wire (544 bits), 68 bytes captured (544 bits) on interface wlp0s20f3, id 0
Data (26 bytes)
0000 aa 55 00 64 b0 53 17 00 00 00 0e 00 03 0a 66 08 .U.d.S........f.
0010 01 01 ff ff 00 00 00 00 f5 36 .........6
Data: aa550064b053170000000e00030a66080101ffff00000000f536
[Length: 26]
675 58.959788972 192.168.1.160 255.255.255.255 UDP 61 9988 → 8899 Len=19
Frame 675: 61 bytes on wire (488 bits), 61 bytes captured (488 bits) on interface wlp0s20f3, id 0
Data (19 bytes)
0010 00 7b ae .{.
Data: aa550064b053170000000e0003030101007bae
[Length: 19]
718 63.894744981 192.168.1.160 255.255.255.255 UDP 61 9988 → 8899 Len=19
Frame 718: 61 bytes on wire (488 bits), 61 bytes captured (488 bits) on interface wlp0s20f3, id 0
Data (19 bytes)
0010 00 7b ae .{.
[Length: 19]
733 65.534560776 192.168.1.160 255.255.255.255 UDP 61 9988 → 8899 Len=19
Frame 733: 61 bytes on wire (488 bits), 61 bytes captured (488 bits) on interface wlp0s20f3, id 0
Data (19 bytes)
0010 01 ba 6e ..n
[Length: 19]
- Here is a brief interpretation of the packets (initial hypothesis):
Turning the light off: aa550064b053170000000e0003030101007bae
"aa55": Possible start of the packet or a header identifier.
"0064": Packet length, indicating a 100-byte packet.
"b053": Identifier or protocol-specific information related to the smart light.
"17000000": unclear
"0e": Unclear
"000303010100": This portion likely contains control data specific to the smart light. The sequence "0100" might indicate a command to turn the light off.
"7bae": Checksum or cryptographic value for error detection or verification.
Turning the light on: aa550064b053170000000e000303010101ba6e
"17000000": unclear
"0e": Unclear
"000303010101": This portion likely contains control data specific to the smart light. The sequence "0101" might indicate a command to turn the light on.
"ba6e": Checksum or cryptographic value for error detection or verification.
- This is all I got so far concerning the WiFi packets analysis. I don’t know where to go from here.
Analysis of communication over Bluetooth:
I have performed this analysis on the Smart Pad only because if I am able to control the Smart Pad, I am able to control the Skylight.
- I wasn’t able to sniff bluetooth packets with my computer using Wireshark, although it is possible (but I don’t know how, if you could give me some directions it would be great).
- Using
bluetoothctl,btmgmtandgatttool, I was able to figure out the following handles:
[A4:C1:38:7C:BC:49][LE]> char-desc
handle: 0x0001, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x0002, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0003, uuid: 00002a00-0000-1000-8000-00805f9b34fb
handle: 0x0004, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0005, uuid: 00002a01-0000-1000-8000-00805f9b34fb
handle: 0x0006, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0007, uuid: 00002a04-0000-1000-8000-00805f9b34fb
handle: 0x0008, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x0009, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x000a, uuid: 00002a50-0000-1000-8000-00805f9b34fb
handle: 0x000b, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x000c, uuid: 00002a26-0000-1000-8000-00805f9b34fb
handle: 0x000d, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x000e, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x000f, uuid: 00010203-0405-0607-0809-0a0b0c0d2b12
handle: 0x0010, uuid: 00002901-0000-1000-8000-00805f9b34fb
handle: 0x0011, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x0012, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0013, uuid: 00002adc-0000-1000-8000-00805f9b34fb
handle: 0x0014, uuid: 00002901-0000-1000-8000-00805f9b34fb
handle: 0x0015, uuid: 00002902-0000-1000-8000-00805f9b34fb
handle: 0x0016, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0017, uuid: 00002adb-0000-1000-8000-00805f9b34fb
handle: 0x0018, uuid: 00002901-0000-1000-8000-00805f9b34fb
handle: 0x0019, uuid: 00002902-0000-1000-8000-00805f9b34fb
handle: 0x001a, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x001b, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x001c, uuid: 00002ade-0000-1000-8000-00805f9b34fb
handle: 0x001d, uuid: 00002901-0000-1000-8000-00805f9b34fb
handle: 0x001e, uuid: 00002902-0000-1000-8000-00805f9b34fb
handle: 0x001f, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0020, uuid: 00002add-0000-1000-8000-00805f9b34fb
handle: 0x0021, uuid: 00002901-0000-1000-8000-00805f9b34fb
handle: 0x0022, uuid: 00002902-0000-1000-8000-00805f9b34fb
handle: 0x0023, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x0024, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0025, uuid: 00010203-0405-0607-0809-0a0b0c0d7fdf
handle: 0x0026, uuid: 00002901-0000-1000-8000-00805f9b34fb
handle: 0x0027, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x0028, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0029, uuid: 00002a05-0000-1000-8000-00805f9b34fb
handle: 0x002a, uuid: 00002901-0000-1000-8000-00805f9b34fb
handle: 0x002b, uuid: 00002902-0000-1000-8000-00805f9b34fb
handle: 0x002c, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x002d, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x002e, uuid: 00010203-0405-0607-0809-0a0b0c0d1a11
handle: 0x002f, uuid: 00002901-0000-1000-8000-00805f9b34fb
- And the following services:
[A4:C1:38:7C:BC:49][LE]> primary
attr handle: 0x0001, end grp handle: 0x0007 uuid: 00001800-0000-1000-8000-00805f9b34fb
attr handle: 0x0008, end grp handle: 0x000c uuid: 0000180a-0000-1000-8000-00805f9b34fb
attr handle: 0x000d, end grp handle: 0x0010 uuid: 00010203-0405-0607-0809-0a0b0c0d1912
attr handle: 0x0011, end grp handle: 0x0019 uuid: 00001827-0000-1000-8000-00805f9b34fb
attr handle: 0x001a, end grp handle: 0x0022 uuid: 00007fdd-0000-1000-8000-00805f9b34fb
attr handle: 0x0023, end grp handle: 0x0026 uuid: 00010203-0405-0607-0809-0a0b0c0d7fde
attr handle: 0x0027, end grp handle: 0x002b uuid: 00001801-0000-1000-8000-00805f9b34fb
attr handle: 0x002c, end grp handle: 0x002f uuid: 00010203-0405-0607-0809-0a0b0c0d1a10
And I managed to figure out the following information about said handles (by interrogating the Smart Pad over bluetooth and interpreting in ASCII the answers I got):
This is all I got so far, I really don’t know where to go from here, I would really appreciate help from anyone! Any hint or direction I could take will be very much appreciated!
PS: In a moment of desperation, I reached out to the company asking if I could talk to the engineers. Obviously it won’t work, but it was worth giving it a try.
