I have a pesetech artificial skylight. Really awesome device that has a very rudimentary connection in google, but part of why I transitioned to home assistant was hoping that pesetech would be able to be controlled. The light and the switch that control it (as well as the app) appear to be operated by a bluetooth connection, although the light also has wifi, but I cannot seem to get into the connection. I assume the google integration works via the wifi connection, but I suspect that the wifi module in the light is not always active so when commands are sent from google they do not go through. Please help! thank you.
