Forgive my lack of understanding, but is there any reason HA couldn’t just add a UI drop down menu in the weather integration configuration to select what forecast data is desired (ie high temperatures x5 days) and how often you’d like the forecast data to be refreshed, and keep the truncated forecast data as an attribute instead of using a service call? I’d be fine with twice a day, three times a day, or four times a day refreshes, but I’ll still need to store the relevant forecast data somewhere.
I use the forecast high temperature data in three binary sensor template entities to identify when to open the windows to regulate the indoor temperature with passive air flow. I just moved them from the YAML configuration to the new UI template helper, but it seems I would have to move it back to the YAML to utilize this trigger action template get_weather service call.
I would have to poll the API three times every so often for the same forecast high temperature data instead of pulling it from cache. Although perhaps I could make a new template sensor to get the weather data and store it as attributes for my other binary sensors to reference, similar to the original weather forecast attributes… seems redundant until HA sunsets the original attributes.
I also use the forecast conditions to look for snowfall in the next 48h to warn me in my daily briefing TTS script. It is helpful to know when I come home if it will snow tomorrow so I can wake up early and scrape the frost/ice/snow off the vehicle before I commute to work. I suppose I’d have to use the get_weather service in the automation before this briefing is announced.
