Zenia
(Yevgeniy)
May 21, 2024, 10:25pm
1
Hello everyone. I have a problem with my automation for pets waiting outside of the backyard door. I used t have a ld2410 sensor there, but it was a lot of falls alarms (rain, bee, and etc), so I decided to use TOF sensor VL53L0X with esp32. But cant figure it out how to make automation to trigger only if distance between 5cm and 90cm. I know, I should use a condition IF but not really good in coding like that.
Here is my esp32 code:
esphome:
friendly_name: Pets Presence-2
esp32:
board: esp32dev
framework:
type: arduino
version: recommended
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: " "
ota:
password: " "
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Pets-Presence-2"
password: " "
captive_portal:
i2c:
sda: 22
scl: 21
scan: true
- platform: vl53l0x
name: "Pet Presence"
icon: mdi:paw
address: 0x29
update_interval: 5s
long_range: false
web_server:
port: 80
an my automation:
alias: Pet is waiting outside, Let me in
description: ""
- alias: Pet Outside
platform: state
entity_id:
- sensor.pets_presence_2_pet_presence
to: "on"
for:
hours: 0
minutes: 0
seconds: 45
enabled: false
- platform: state
entity_id:
- binary_sensor.pets_presence_1115h_occupancy_or_movement
to: "off"
alias: Clear
for:
hours: 0
minutes: 1
seconds: 0
enabled: false
- alias: Pet waiting Outside
type: value
platform: device
device_id: 1f8cbca11de7c664ed288495d885eeeb
entity_id: 7465608af8cbbfc09e942d969b74629a
domain: sensor
below: 1
for:
hours: 0
minutes: 0
seconds: 10
- type: value
platform: device
domain: sensor
above: 1
alias: No pet around
condition:
- condition: time
after: "07:30:00"
before: "22:00:00"
- condition: state
entity_id: binary_sensor.back_door_contact
state: "off"
- choose:
- conditions:
- condition: trigger
sequence:
- service: notify.mobile_app_sm_s918u
message: Пустите Домой, Пожалуйста
priority: high
ttl: 0
channel: pets
notification_icon: mdi:paw
- service: tts.google_translate_say
cache: false
entity_id: media_player.masyanya
language: ru
enabled: false
- alias: Let me in
if:
id:
- Detected-2
then:
priority: high
ttl: 0
channel: pets
cache: false
language: ru
else: []
mode: single
It’s a lot of unused or disabled triggers and conditions, but project is in trials and mistakes stage
Thank you in advanced for help
petro
(Petro)
May 23, 2024, 1:00pm
3
Just add an and condition via the UI and check that the sensor is above 5 and below 90.
Add the condition to the overall conditions or in each choose. No logic required.
Zenia
(Yevgeniy)
May 23, 2024, 1:13pm
4
Will try, I think I already did this and for some reason it was not working the way I wanted. Thank you. Will report back.
Zenia
(Yevgeniy)
May 24, 2024, 11:30am
5
Good day
I did like you suggested Petro, but now it’s triggering even if no pets sitting in front of the sensor.
description: ""
platform: state
entity_id:
to: "on"
for:
hours: 0
minutes: 0
seconds: 45
enabled: false
- platform: state
entity_id:
to: "off"
alias: Clear
for:
hours: 0
minutes: 1
seconds: 0
enabled: false
type: value
platform: device
domain: sensor
below: 0.8
for:
hours: 0
minutes: 0
seconds: 10
above: 0.1
- type: value
platform: device
domain: sensor
above: 1
condition:
- condition: time
after: "07:30:00"
before: "22:00:00"
- condition: state
state: "off"
- choose:
- conditions:
sequence:
priority: high
ttl: 0
channel: pets
cache: false
language: ru
enabled: false
- alias: Let me in
if:
id:
- Detected-2
then:
priority: high
ttl: 0
channel: pets
cache: false
language: ru
else: []
mode: single
So, I am asking for help again.
Any ideas what I am doing wrong and how to fix that
Thank you
petro
(Petro)
May 24, 2024, 11:31am
6
You didn’t add the condition… Please try to add the condition. You’ve already added 2 other conditions to your conditions. This is no different than those… you can do it.
Zenia
(Yevgeniy)
May 25, 2024, 1:59pm
7
@petro ,sorry, but I fill stupid. Can’t think of any other conditions to add to this automation. Please name one . I clean my code a little bit:
description: ""
type: value
platform: device
domain: sensor
below: 0.8
for:
hours: 0
minutes: 0
seconds: 10
above: 0.1
- type: value
platform: device
domain: sensor
above: 1
condition:
- condition: time
after: "07:30:00"
before: "22:00:00"
- condition: state
state: "off"
- alias: Let me in
if:
id:
- Detected-2
then:
priority: high
ttl: 0
channel: pets
cache: false
language: ru
else: []
mode: single
Thank you
Zenia
(Yevgeniy)
May 25, 2024, 3:04pm
9
I thought it inside the first( trigger) part
stevemann
(Stephen Mann (YAML-challenged))
May 25, 2024, 3:09pm
10
I use the TOF sensor to tell me if the trashbin is present. I know it could be done in one automation, but why complicate things?
Here’s my automations:
alias: trashbin-present
description: Turns off a light if the trashbin distance is within one meter
- platform: numeric_state
entity_id:
- sensor.trashbin_vl53_2
above: 0
below: 0.51
condition: []
data: {}
entity_id: input_boolean.trashbin_present
mode: single
alias: trashbin-gone
description: Turns off 'input_boolean.trashbin_present' if the bin is gone
entity_id:
above: 0.52
condition: []
- service: input_boolean.turn_off
data: {}
mode: single
Zenia
(Yevgeniy)
May 25, 2024, 3:22pm
11
Well, I think it’s pretty much the same automation. I try to accomplish only one thing: if backyard door is closed and time between 7:30Am and 9:00PM and pet is seating outside, waiting to get inside, it’s send a command to Google hub to announce: Pets is outside, Let me in, and send notification to my phone with same message. Everything is working, except, it’s trigger even if no pet outside( I think it’s to sensitive or ???) Used to have a LD2410 but even havy rain was triggering this automation.
petro
(Petro)
May 25, 2024, 3:23pm
12
No, you need it as a condition.
stevemann
May 25, 2024, 3:24pm
13
Look down. Orient the sensor to be looking down where the pets are trained to sit.
Zenia
(Yevgeniy)
May 25, 2024, 3:30pm
14
like this?
description: ""
- type: value
platform: device
domain: sensor
above: 1
entity_id:
for:
hours: 0
minutes: 0
seconds: 15
above: 0.1
below: 0.9
alias: Pets waiting outside
condition:
- condition: time
after: "07:30:00"
before: "22:00:00"
- condition: state
state: "off"
- condition: numeric_state
entity_id: sensor.pets_presence_2_pet_presence
above: 0.1
below: 0.9
- alias: Let me in
if:
id:
- Detected-2
- Detected-3
then:
priority: high
ttl: 0
channel: pets
cache: false
language: ru
else: []
mode: single
but It’s same condition in trigger and in conditions
otherwise it’s not let me save this automation.
Zenia
(Yevgeniy)
May 25, 2024, 3:31pm
15
Sensor is on the floor level(outside on the door jam)
