I’m trying to setup this add-on. Installing seems to work fine, authentication through SMS works well, but I can’t reach the add-on through the IP. I think it’s because the add-on didn’t ask for the network setup part. When I look in the configuration of the add-on within the HA UI, there are no ports open under Network.
Can someone help me out?
EDIT
I’ve installed the docker version on my HA machine. This way the 5000 port is open, it works perfect now
News: for enable remote control on all car gasoline diesel in app
Logout from app
Close app
Reopen app
Localise in BE/francaise language
Login
Wait for enable remote with sms and code (otp).
Wait 1 hour for email completation
Hi, I followed your instructions but I can’t find the OTP function inside the app.
Do I have to wait for it to appear?
I’m afraid I didn’t understand correctly.
P.S.
My car is not the diesel model but the 1.2 petrol model.
However, I hope that if the remote control was activated for diesel models the same could have happened for petrol ones.
Also, I’m in Italy and I use iOS on an iphone 13 Pro.
As for the country/language options, I can choose Nederlands/Nederland or France Metropolitain/French.
I can’t find Nederland/francaise.
the latest version 2023.6.0 has shown warnings in regards to the way that the sensors and switch platform is current being written.
I’ve tried following the guide but can’t seems to get it parse properly. Anyone had any luck in getting this through?
if yes, can I please see how you’ve done it? Cheers
But with 0.0.0.0 i didn’t get nor date with vehicleinfo.
The problem shoud be the template error (but why, other user have no problem):
Logger: homeassistant.helpers.template_entity
Source: helpers/template_entity.py:422
First occurred: 22:36:38 (35 occurrences)
Last logged: 23:13:21
TemplateError(‘UndefinedError: ‘None’ has no attribute ‘attributes’’) while processing template ‘Template<template=({{ states.sensor.peugeot_e2008.attributes[“energy”][0][“autonomy”] }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.e2008_battery_autonomy’
TemplateError(‘UndefinedError: ‘None’ has no attribute ‘attributes’’) while processing template ‘Template<template=({{ states.sensor.peugeot_e2008.attributes[“energy”][0][“charging”][“status”] }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.e2008_charging_status’
TemplateError(‘UndefinedError: ‘None’ has no attribute ‘attributes’’) while processing template ‘Template<template=({{ states.sensor.peugeot_e2008.attributes[“timed_odometer”][“mileage”] }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.e2008_mileage’
TemplateError(‘UndefinedError: ‘None’ has no attribute ‘attributes’’) while processing template ‘Template<template=({{ states.sensor.peugeot_e2008_charge_control.attributes["_next_stop_hour"]}}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.e2008_stop_hour’
TemplateError(‘UndefinedError: ‘None’ has no attribute ‘attributes’’) while processing template ‘Template<template=({{ states.sensor.peugeot_e2008_charge_control.attributes[“percentage_threshold”] }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.e2008_threshold’
Try to replace 0.0.0.0 with the actual IP address of the machine it’s running on.
Do you get a sensor from the rest platform you set up? This is my config (note that I’m running the add-on on port 5001 and I’m pulling some additional attributes):
But I didn’t have the sensor “peugot_2008”!!! Why?
In the Browser I get Data with get_vehicleinformation!
The differenz between your Coding and my (and the coding of Flodu31) is, i have no line “sensor 2008:”
Do you have your coding in sensor.yaml or configuration.yaml?
In the sensor.yaml it is not possible for to insert this line. So I insert only this sensor in the configuration.yaml. That works!
Than I inserted all sensor in the configuration.yaml, it works!
But I did not want to insert all sensor in the configuration.yaml. What was your way?
Later I see, with the inserting all sensors in configuration.yaml I did not get any errors, but no sensor was generated!?
What is the way you assign the attributes of your 208-Sensor to the single sensor eg batery_level?
I have everything in configuration.yaml with no sensor.yaml, so I don’t know why it works in one place but not the other. But it’s good that it’s working now.
I noticed that PSA Car Controller now (sometimes) include the location of the car, this can be added to HA if you add last_position in the list under json_attributes in the main sensor, then add a sensor like this (it can also be condensed into the automation, but I like to have the “raw” output):
e208_last_position:
friendly_name: "e208 Last Position Coordinates"
value_template: '{{ states.sensor.peugeot_e208.attributes["last_position"]["geometry"]["coordinates"] }}'
And then create an automation that updates a device tracker with the location every minute:
Hey
yesterday night was i able to solve the problem. The problem, i moved the code of sensor.yaml to configuration.yaml. So I had 2x rest and 2x template, but without errors.
It works, thank you verry much!
Your sensor I will look again.
And your solution with the device tracker is interesting. which one do you use?
I only just implementet the device tracker, so currently I’m only seeing the inaccuracy of the GPS (I hope…), but it’s showing up nicely on a map and it looks like it’s updating very frequently:
