Hey, I am using the home assistant add-on and I don’t know exactly which IP should I use… since it’s a docker container I imagine localhost won’t work, neither my Raspberry Pi local IP right? Should I use the IP it shows in the logs when I launch the add-on? Mine says:
2023-08-04 22:59:22,035 :: INFO :: update_data
2023-08-04 22:59:24,307 :: INFO :: * Running on http://0.0.0.0:5000/ (Press CTRL+C to quit)
I use the hostname. So when you open PSA Controller addon page and you see all the toggles “start on boot”, “watchdog”, etc. In the same place, you’ll see also hostname field. That’s the value I use plus the :5000 port.
yeah, you need the official app to keep the connection to the car (the car will dropp the connection if the it drives for a while without being connected to your phone).
I got some location info on the 21st. of July, then nothing and the consistantly since the 27th. of July.
Is possible to activate a preconditioning program using this API?
So if I have schedule for 8am, I would like to be able active/deactivate it. In summer time using HA to trigger the preconditioning on/off is not much of an issue, but I’m more thinking about the winter where I assume the outside temperature plays more a role in the preconditioning duration.
Neither does the IP if you did not give Home Assistant one from DHCP. This is a no go for devices that stay in your LAN forever. My IP is the same since I started using HA. It’s more likely that your DNS will make problems and the addin will not find anything anymore than this happening.
No my HA has a static IP . Each add-in is allocated it’s own internal IP . The host name of the add-in is associated to that internal IP ( Each add-in is a docker container with its own internal network).
I’ve lost the graphs on Summery page and the map on the Map page after I upgraded the add-on to v3.0.13… Have any of you expirienced something similar?
Summary works on mine . Map is always hit and miss for me, currently not working . It seem to be logging journeys OK . Not been anywhere in the car for a couple of days , will update again when I have been somewhere ( sad)
I try to install the add on in HA but get the message
Failed to install add-on
Can't install flobz/psa_car_controller:v3.1.0: 404 Client Error for http+docker://localhost/v1.43/images/flobz/psa_car_controller:v3.1.0/json: Not Found ("No such image: flobz/psa_car_controller:v3.1.0")
Anyone knows how to solve this? It works installing other add ons.
After my problems at beginging it works fine. Now I have another error
Logger: homeassistant.components.rest.util
Source: components/rest/util.py:37
Integration: RESTful (documentation, issues)
First occurred: 20:23:26 (3 occurrences)
Last logged: 20:25:26
REST result could not be parsed as JSON
