OK. I managed to get it working. Here are what the instruction may have to be amended on the HASSIO installation side (step 4 in OP onwards):
0. There are 3 files that we need to put into our Homeassistant folder (for me, I put them into /usr/share/hassio/homeassistant/custom_components/pfSense):
PfsenseFauxapi.py, pffa_get_system_stats.py (can be any name), and "_version_.py"
All the three .py files must be in a same directory
Inside the PfsenseFauxapi.py, line no. 24, we have to delete the ‘.’ (dot) from the "
from .__version__ import __version__"
, to read as"from __version__ import __version__"
; otherwise, it will report error -
Inside the pffa_get_system_stats.py, I need to change every ‘Fauxapi’ to be ‘PfsenseFauxapi’; otherwise, it will report ImportError: cannot import name ‘Fauxapi’. I don’t know why, but changing it makes it work.
The sample configuration.yaml above needs to insert “Platform: file” and “file_path” after the command-line (see my config below).
Here is the result from direct run by command line: python3 pffa_get_system_stats 192.xxx.x.x api-key secrekey
Last warning, the api-key length must be between 12 and 40 characters (alphanumeric) and the secret-key length must be between 41 and 128 characters. We can define them ourselves. I made it too short and it didn’t work until I make the secret-key long enough.
Next steps are to add its sensors in my HASSIO configuration.yaml and display as a group.
Here is the result:
As I put all fauxapi files in “/usr/share/hassio/homeassistant/custom_components/pfSense” folder, I have to define like these in my configuration.yaml
whitelist_external_dirs:
- /config/custom_components/pfSense
- /config
#-- pfSense -----
#this will call the python script and store the cpu temp information in a sensor. the script will export
#the rest of the data into a file. we cant dump all of the data into 1 sensor since there is a 255 character
#limit for the sensor.
- platform: command_line
command: "python3 custom_components/pfSense/pffa_get_system_stats.py 192.168.x.x ...your fauxapi api-key.... ...your fauxapi-secrit-key..."
- platform: file
file_path: pfSense_stats.json
value_template: '{{ value_json["data"]["stats"]["temp"] }}'
unit_of_measurement : '°C'
- platform: file
value_template: '{{ value_json["data"]["stats"]["uptime"] }}'
- platform: file
value_template: '{{ value_json["data"]["stats"]["mem"] }}'
unit_of_measurement : '%'
- platform: file
value_template: '{{ ( ( ((value_json["data"]["stats"]["cpu"].split("|")[0] | float) / (value_json["data"]["stats"]["cpu"].split("|")[1] | float)) - 1.0 ) * 100.0 ) | round(1) }}'
- platform: file
value_template: '{{ value_json["data"]["stats"]["mbufpercent"] }}'
In the groups.yaml
pfSense Monitor:
control: hidden
entities:
- sensor.pfsense_cpu
- sensor.pfsense_cpu_temp
- sensor.pfsense_mbufpercent
- sensor.pfsense_mem
- sensor.pfsense_uptime
working pffa_get_system_stats.py, amended as described above:
import os, sys, json
sys.path.append(os.path.abspath(os.path.join(os.path.curdir, '../client-libs/python'))) # hack to make this work in-place
from PfsenseFauxapi import PfsenseFauxapi
# check args exist
if(len(sys.argv) < 4):
print()
print('usage: ' + sys.argv[0] + ' <host> <apikey> <apisecret>')
print()
print('pipe JSON output through jq for easy pretty print output:-')
print(' $ ' + sys.argv[0] + ' <host> <apikey> <apisecret> | jq .')
print()
sys.exit(1)
# config
fauxapi_host=sys.argv[1]
fauxapi_apikey=sys.argv[2]
fauxapi_apisecret=sys.argv[3]
PfsenseFauxapi = PfsenseFauxapi(fauxapi_host, fauxapi_apikey, fauxapi_apisecret, debug=False)
# system_stats
print(json.dumps(
PfsenseFauxapi.system_stats())
open('pfSense_stats.json', 'w').close() # clear data
with open('pfSense_stats.json', 'a') as stat_file:
print(json.dumps(
PfsenseFauxapi.system_stats()), file=stat_file)
