I consider mesuring ph of the water of my swimming pool and accessing it via Home Assistant.
I am totally a new beginner with Home Assistant (but not in python).
After reading all the doc in the website, i am still wondering what is the best and fastest solution to fetch my ph sensor data and displaying it on HA.
here is my hardware configuration:
- ph probe connected to a rpi on GPIO I2C bus.
- home assistant running on the same rpi.
I am currently able to read my Ph data via GPIO I2C bus and storing it in a .txt file.
How can i simply read this .txt file to feed Home assistant ?
- I am thinking about implementing MQTT exchange but i find it a little bit complicated just to read a .txt file that is on the same rpi than the one running HA.
- I am also thinking about using REST or python API to post these data to HA. But again, it seems to me a little bit heavy just for reading a .txt file.
Any advice about how to proceed would be very appreciated.
regards,
