Hey guys, just wanted to see if anyone else has experience with this. I’m getting Phantom deCONZ events that are turning my lights off due to an automation I have set up. I’m definitely not pressing the button so this is weird.
The ZigBee button is a Samsung SmartThings button.
The dongle is a ConBee II
The trigger for my lights off automation looks like this:
That is obviously the unique id of the button, and the event is a button double press.
I’ve never had problems with this automation in the past, but as of the last week or so, I’ve been having this issue.
I have the same issue with the same set-up as you so I have 2 Samsung SmartThings buttons connected to a ConBee II and I had to disconnect them from the lights they were controlling because of the phantom fired events.
I tried to debug but there is nothing unusual in the debugger info.
Additionally I noticed this behavior about 2 weeks ago after I update Home Assistant, don’t know if this will help. Did you find any solution?
I am noticing the same thing with numerous smartthings buttons. I am using node-red for automation but it is repeating the same thing for hours at a time. It affects the buttons that were utilizing toggle functions, on or off commands are also being replicated, but it’s not critical since it’s only repeating the last command sent. Deconz/smartthings buttons worked flawlessly for years on my system and since update, in late Jan I’ve had to remove many of my buttons or change the setup of them. It’s frustrating, especially since nothing in my setup changed at that time, just an update.
Yeah, it’s definitely a Samsung SmartThings Button issue specifically. I have ZigBee buttons from 3 other brands and none of them have this issue. Really a bummer because I like the form factor of the SmartThings buttons the most. Maybe there will be a patch upcoming?
Found myself recently having this problem as well. The button worked fine during the initial pair. About 4 or so hours later, phantom events starting appearing.
Not sure whether you have tested but for me the latest update to Deconz add-on (6.10.0) has addressed this issue for me and my Samsung buttons are now working properly again (after deleting and re-adding them).
