I have CT clamps around both sides of my split-single-phase US residential service. I’ll probably post it in another place when I can identify one… I’m using the six channel board available through CircuitSetup but posting here because I suspect a lot of CircuitSetup boards wind up in Home Assistant installations.
I see phantom negative consumption and am trying to track down where it’s coming from. I kind of know where it’s coming from, I’m not exactly using the same grade of hardware my utility is using - the CircuitSetup gizmo gets my service input, car charger and two other circuits in my kitchen, and the rest of the inputs are provided from various smart plugs. I know I can’t get it to balance perfectly but want to get it… closer than it is now.
I have no solar or battery and it’s impossible to get those negative values shown, they’re just a rounding error of sorts I think.
I know that what I really need to do is run my Chevy volt down to empty then plug in the charger and confirm amperage being delivered according to the OBD-2 reader matches the two phases from the utility with everything else shut off. Haven’t found a convenient time to do that quite yet.
esphome:
friendly_name: Power Meter ESPHome 0d42f4
min_version: 2024.11.0
name_add_mac_suffix: false
# CircuitSetup 6 Channel Energy Meter Main Board example config
# See all options at https://esphome.io/components/sensor/atm90e32.html
substitutions:
# Change the disp_name to something you want
disp_name: Energy Meter
friendly_name: My Energy Metering
# Interval of how often the power data is updated
update_time: 10s
# Change current_cal to the corresponding CT's that you're using
# If different CTs per current channel, remove or change "${current_cal}" from
# "gain_ct" below and replace with the CT calibration number respectively
# Current Transformers:
# 20A/25mA SCT-006: 11143
# 30A/1V SCT-013-030: 8650
# 50A/1V SCT-013-050: 15420
# 50A/16.6mA SCT-010: 41334
# 80A/26.6mA SCT-010: 41660
# 100A/50ma SCT-013-000: 27518
# 120A/40mA: SCT-016: 41787
# 200A/100mA SCT-024: 27518
# 200A/50mA SCT-024: 55036
current_cal_ct1: '27518'
current_cal_ct2: '27518'
current_cal_ct3: '11143'
current_cal_ct4: '8650'
current_cal_ct5: '8650'
current_cal_ct6: '11143'
# This only needs to be changed if you're using something other than the
# Jameco 9VAC Transformer:
voltage_cal: '7305'
packages:
common: github://CircuitSetup/Expandable-6-Channel-ESP32-Energy-Meter/Software/ESPHome/6chan_common.yaml
esp32:
board: esp32dev
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
web_server:
port: 80
spi:
clk_pin: 18
miso_pin: 19
mosi_pin: 23
wifi:
ssid: !secret wifi_ssid
bluetooth_proxy:
active: true
- platform: wifi_signal
update_interval: 60s
# IC1
- platform: atm90e32
cs_pin: 5
phase_a:
voltage:
name: ${disp_name} Volts A
accuracy_decimals: 1
current:
name: ${disp_name} CT1 Amps
phase_angle:
name: ${disp_name} CT1 Phase Angle
harmonic_power:
name: ${disp_name} CT1 Harmonic Power
power:
name: ${disp_name} CT1 Watts
gain_voltage: ${voltage_cal}
gain_ct: ${current_cal_ct1}
phase_b:
current:
name: ${disp_name} CT2 Amps
power:
name: ${disp_name} CT2 Watts
gain_ct: ${current_cal_ct2}
phase_angle:
name: ${disp_name} CT2 Phase Angle
harmonic_power:
name: ${disp_name} CT2 Harmonic Power
phase_c:
current:
name: ${disp_name} CT3 Amps
power:
name: ${disp_name} CT3 Watts
gain_ct: ${current_cal_ct3}
frequency:
name: ${disp_name} Freq A
line_frequency: 60Hz
gain_pga: 1X
update_interval: ${update_time}
# IC2
cs_pin: 4
phase_a:
voltage:
name: ${disp_name} Volts B
current:
name: ${disp_name} CT4 Amps
power:
name: ${disp_name} CT4 Watts
gain_ct: ${current_cal_ct4}
phase_b:
current:
name: ${disp_name} CT5 Amps
power:
name: ${disp_name} CT5 Watts
gain_ct: ${current_cal_ct5}
phase_c:
current:
name: ${disp_name} CT6 Amps
power:
name: ${disp_name} CT6 Watts
gain_ct: ${current_cal_ct6}
frequency:
name: ${disp_name} Freq B
gain_pga: 1X
# Total Amps
name: ${disp_name} Total Amps
lambda: return id(ct1Amps).state + id(ct2Amps).state;
accuracy_decimals: 2
unit_of_measurement: A
device_class: current
# Total Watts
name: ${disp_name} Total Watts
lambda: return id(ct1Watts).state + id(ct2Watts).state ;
unit_of_measurement: W
device_class: power
# Total kWh
lambda: return (id(ct1Amps).state + id(ct2Amps).state) * .001;
unit_of_measurement: kWh
name: ${disp_name} CT1 VA # Apparent Power
lambda: return id(ic1Volts).state * id(ct1Amps).state;
unit_of_measurement: VA
name: ${disp_name} CT2 VA # Apparent Power
lambda: return id(ic2Volts).state * id(ct2Amps).state;
# kWh per channel
- platform: total_daily_energy
name: ${disp_name} CT1 kWh
power_id: ct1Watts
filters:
- multiply: 0.001
device_class: energy
state_class: total_increasing
name: ${disp_name} CT2 kWh
power_id: ct2Watts
filters:
- multiply: 0.001
name: ${disp_name} CT3 kWh
power_id: ct3Watts
filters:
- multiply: 0.001
name: ${disp_name} CT4 kWh
power_id: ct4Watts
filters:
- multiply: 0.001
name: ${disp_name} CT5 kWh
power_id: ct5Watts
filters:
- multiply: 0.001
name: ${disp_name} CT6 kWh
power_id: ct6Watts
filters:
- multiply: 0.001
name: ${disp_name} CT1 Power Factor
lambda: |-
float watts = id(ct1Watts).state;
float va = id(ct1VA).state;
if (va == 0) {
return 0.0;
} else {
float pf = watts / va;
if (pf!= pf) { // Direct NaN check
return 0.0;
} else {
return pf;
unit_of_measurement: ""
name: ${disp_name} CT2 Power Factor
lambda: |-
float watts = id(ct2Watts).state;
float va = id(ct2VA).state;
if (va == 0) {
return 0.0;
} else {
return 0.0;
} else {
return pf;
#kWh
# - platform: total_daily_energy
# name: ${disp_name} Total kWh
# power_id: totalWatts
# filters:
# - multiply: 0.001
# unit_of_measurement: kWh
# device_class: energy
# state_class: total_increasing
name: "Free Heap Memory"
unit_of_measurement: "bytes"
lambda: |-
#include <esp_heap_caps.h>
return esp_get_free_heap_size();
update_interval: 60s # Adjust as needed
switch:
- platform: restart
time:
- platform: sntp
Here’s my power meter configuration from ESP32, it took a hot second to get the code just right so it wouldn’t send NaN’s on startup and cause Home Assistant to disregard those sensors.
I am aware that the phase measurements are total BS until I have two discrete 9 VAC sources connected to the board from both sides of the split-phase, and probably traces cut. I think the power factor calculation might also be similarly affected.
I think that the calibration is a matter of adjusting the current_cal values while the car is charging at a known amperage? Both for the 30A clamps on its circuit and then getting the 100A clamps to read the same amount, right?
