Phantom Occupancy and Motion Sensors
I am going through my first day detecting new devices and setting them up, and two devices with 2 sensors each appeared. Each has motion and occupancy within them.
H5127 by Govee
I do not have any of these on my network (as far as I know), only Govee outlets and led bulbs.
Should I be concerned? Is this just a case of an incorrect identification of another device?
I found a thread referring to this but it is old and dates back to 2021.
Thanks!
Which integration is adding these devices to HA?
Govee Bluetooth.
Name
Entity ID
Integration
Area
Status
H51278629 Motion
binary_sensor.h51278629_motion
Govee Bluetooth
H51278629 Occupancy
binary_sensor.h51278629_occupancy
Govee Bluetooth
H5127933B Motion
binary_sensor.h5127933b_motion
Govee Bluetooth
H5127933B Occupancy
binary_sensor.h5127933b_occupancy
Govee Bluetooth
Signal Strength
sensor.h51278629_signal_strength
Govee Bluetooth
Signal Strength
sensor.h5127933b_signal_strength
Govee Bluetooth
Likely a neighbor, unless you are somewhere remote enough where that’s not possible.
Inside my house and through a block wall? I did not think BT was that robust.
Depends how far away they are and also, just because it showed up doesn’t mean it would have a reliable/useable connection.
I have had probably a dozen BT devices show up from neighbors.
Copy that. So this leads me to ask… if I just delete those two instances, will they continue to pop up? And if they do, can I block/ignore them?
ADDED: It would be cool if I could get LQI or RSSI on those detections to see if they ARE faint and distant.
Yep, when anything gets discovered it has an ‘ignore’ button.
