Peter_West
(Peter West)
October 13, 2020, 8:14pm
1
Is anyone able to help me please with a strange Z-Wave issue?
I only have two Z-Wave devices. One if the Z-Stick Gen 5 and the other is an Aeotec Multisensor 6.
However, when I go into view my nodes I have two ‘phantom’ nodes which have an index but no model or manufacturer. The query stage is stuck at ‘ProtocolInfo’ but the failed column is not ticked.
The two other devices are also in the list with all columns completed as i’d expect.
Is there any way to get rid of these ‘phantom’ entries from the configuration please?
Pete
finity
October 13, 2020, 8:32pm
2
do they show up in your states page as zwave.xx?
And if they are there do they show as “is_failed: true”?
If they do show as failed you should be able to go to the zwave control panel and remove the failed nodes from there.
Peter_West
(Peter West)
October 13, 2020, 8:37pm
3
Unfortunately not. No devices in the states page with zwave. as the prefix.
Pete
Peter_West
(Peter West)
October 13, 2020, 8:42pm
4
Just to give some background - I have no idea if i’ve got this configured the right way.
I have the OpenZWave (beta) integration installed but also the Open ZWave add-on in the Supervisor tab. I’m not 100% sure if I need both or not.
If I use the Web UI in the add-on then I only see the two devices. The phantom entries only show up in the integration.
Pete
finity
October 16, 2020, 5:48pm
5
Yes, you need both. That’s how it works right now.
Other than that I have little experience with the OZW Beta. I have played with it a but I run the built-in zwave integration.
Peter_West
(Peter West)
October 17, 2020, 1:07pm
6
Ok, thanks for confirming that. At least I know i’ve got part of the setup correct.
The application in the Supervisor panel shows the two phantom devices but if I click one and then try to delete it the following message is shown:
Waiting for the controller to Enter Exclusion Mode.
I don’t know how to do that. Do I need to press the button on the Z-Stick or something?
Pete
finity
October 17, 2020, 2:07pm
7
I doubt that would help.
Have you tried restarting the add-on? Sometimes a “reboot” can perform wonders.
Peter_West
(Peter West)
October 18, 2020, 10:40am
8
It’s been rebooted a number of times for upgrades and so on anyway so I don’t think that would help in this instance.
finity
October 19, 2020, 2:35am
9
Rebooted or restarted?
In this case a restart won’t help because restarting doesn’t restart add-ons. Try restarting the add-on itself. Not HA.
Peter_West
(Peter West)
October 19, 2020, 2:50pm
10
Thanks for the suggestion.
I went into the Supervisor panel and selected OpenZWave from the list of add-ons. Then I clicked RESTART and waited. Then when I open the Web UI I get this:
So, it doesn’t look like this has addressed the issue.
finity
October 19, 2020, 3:01pm
11
Sorry, I’ve got nothing else to suggest at this point.
maybe you could summon fishwaldo or firtof9 for some additional help but I’ll leave that decision up to you.
johntdyer
(John Dyer)
December 15, 2020, 9:41pm
12
Same issue here, I have 3 nodes that dont exist in Home Assistant at all but are visible in the OZW Control panel
Nodes 13,28,29 do not show up in the entries viewer but do show up in the control panel
gcoupe
(Geoff Coupe)
December 16, 2020, 7:19am
13
See this post for a method of deleting phantom nodes when using QT OpenZwave (Beta). It works very well.
I have seen the topic of how to remove dead nodes from a stubborn Z-Wave controller addressed in many different ways. I though I would present a way to do the procedure from the comfort of Home Assistant, using the mqtt.publish service - via the developer tools panel.
Note: If you have an MQTT client you can follow along with the client by subscribing to the OpenZWave/1/event/# topic on your broker. You can do this also by looking at the OpenZWave admin Events panel in Home Assistant.
First we…
