Philio PAN07 Zwave dimmer not working with flip switch
hey guys this Dimmer is wired up with a flip switch and works fine mechanically however over HA I can activate it only If Parameter 3 is set to 1 (activated by a single momentary switch)
I changed the value of Parameter 3 to 3 (activated by an up down switch and now my dimmer works as expected at the switch however I can no longer activate it over zwave.
https://www.blackcatcontrolsystems.com.au/index.php?route=product/product/download&product_id=139&download_id=29
manual referencing the parameters
2018-12-04 14:36:44.479 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2018-12-04 14:36:44.479 Detail, Node003, Refreshed Value: old value=255, new value=255, type=byte
2018-12-04 14:36:44.480 Detail, Node003, Changes to this value are not verified
2018-12-04 14:36:44.480 Detail, Node003, Notification: ValueChanged
2018-12-04 14:36:44.482 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 255
2018-12-04 14:36:44.482 Info, Node003, SwitchMultilevel::Set - Setting to level 255
2018-12-04 14:36:44.482 Info, Node003,   Duration: Default
2018-12-04 14:36:44.482 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0b, 0x00, 0x13, 0x03, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x49, 0xab
2018-12-04 14:36:44.482 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x4a, 0xaf
2018-12-04 14:36:44.495 Detail,
2018-12-04 14:36:44.495 Info, Node003, Sending (Send) message (Callback ID=0x49, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0b, 0x00, 0x13, 0x03, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x49, 0xab
2018-12-04 14:36:44.504 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:36:44.504 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:36:44.520 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x49, 0x00, 0x00, 0x02, 0xa0
2018-12-04 14:36:44.520 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x49 received (expected 0x49)
2018-12-04 14:36:44.520 Info, Node003, Request RTT 24 Average Request RTT 24
2018-12-04 14:36:44.520 Detail,   Expected callbackId was received
2018-12-04 14:36:44.520 Detail,   Expected reply was received
2018-12-04 14:36:44.520 Detail,   Message transaction complete
2018-12-04 14:36:44.520 Detail, Node003, Removing current message
2018-12-04 14:36:44.521 Detail,
2018-12-04 14:36:44.521 Info, Node003, Sending (Send) message (Callback ID=0x4a, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x4a, 0xaf
2018-12-04 14:36:44.529 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:36:44.529 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:36:44.546 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x4a, 0x00, 0x00, 0x02, 0xa3
2018-12-04 14:36:44.546 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x4a received (expected 0x4a)
2018-12-04 14:36:44.546 Info, Node003, Request RTT 25 Average Request RTT 24
2018-12-04 14:36:44.546 Detail,   Expected callbackId was received
2018-12-04 14:36:44.557 Detail, Node003,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x02, 0xd5
2018-12-04 14:36:44.557 Info, Node003, Response RTT 36 Average Response RTT 35
2018-12-04 14:36:44.557 Info, Node003, Received SwitchMultiLevel report: level=2
2018-12-04 14:36:44.557 Detail, Node003, Refreshed Value: old value=0, new value=2, type=byte
2018-12-04 14:36:44.557 Detail, Node003, Changes to this value are not verified
2018-12-04 14:36:44.558 Detail, Node003,   Expected reply and command class was received
2018-12-04 14:36:44.558 Detail, Node003,   Message transaction complete
2018-12-04 14:36:44.558 Detail, Node003, Removing current message
2018-12-04 14:36:44.558 Detail, Node003, Notification: ValueChanged
2018-12-04 14:36:47.666 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2018-12-04 14:36:47.666 Detail, Node003, Refreshed Value: old value=255, new value=255, type=byte
2018-12-04 14:36:47.666 Detail, Node003, Changes to this value are not verified
2018-12-04 14:36:47.666 Detail, Node003, Notification: ValueChanged
2018-12-04 14:36:47.668 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 0
2018-12-04 14:36:47.668 Info, Node003, SwitchMultilevel::Set - Setting to level 0
2018-12-04 14:36:47.669 Info, Node003,   Duration: Default
2018-12-04 14:36:47.669 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0b, 0x00, 0x13, 0x03, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x4b, 0x56
2018-12-04 14:36:47.669 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x4c, 0xa9
2018-12-04 14:36:47.681 Detail,
2018-12-04 14:36:47.681 Info, Node003, Sending (Send) message (Callback ID=0x4b, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0b, 0x00, 0x13, 0x03, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x4b, 0x56
2018-12-04 14:36:47.690 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:36:47.690 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:36:47.706 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x4b, 0x00, 0x00, 0x03, 0xa3
2018-12-04 14:36:47.706 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x4b received (expected 0x4b)
2018-12-04 14:36:47.706 Info, Node003, Request RTT 24 Average Request RTT 24
2018-12-04 14:36:47.706 Detail,   Expected callbackId was received
2018-12-04 14:36:47.706 Detail,   Expected reply was received
2018-12-04 14:36:47.706 Detail,   Message transaction complete
2018-12-04 14:36:47.706 Detail, Node003, Removing current message
2018-12-04 14:36:47.706 Info, Node003, Sending (Send) message (Callback ID=0x4c, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x4c, 0xa9
2018-12-04 14:36:47.715 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:36:47.715 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:36:47.730 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x4c, 0x00, 0x00, 0x02, 0xa5
2018-12-04 14:36:47.731 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x4c received (expected 0x4c)
2018-12-04 14:36:47.731 Info, Node003, Request RTT 24 Average Request RTT 24
2018-12-04 14:36:47.731 Detail,   Expected callbackId was received
2018-12-04 14:36:47.742 Detail, Node003,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x61, 0xb6
2018-12-04 14:36:47.742 Info, Node003, Response RTT 35 Average Response RTT 35
2018-12-04 14:36:47.742 Info, Node003, Received SwitchMultiLevel report: level=97
2018-12-04 14:36:47.742 Detail, Node003, Refreshed Value: old value=2, new value=97, type=byte
2018-12-04 14:36:47.742 Detail, Node003, Changes to this value are not verified
2018-12-04 14:36:47.742 Detail, Node003,   Expected reply and command class was received
2018-12-04 14:36:47.742 Detail, Node003,   Message transaction complete
2018-12-04 14:36:47.743 Detail,
2018-12-04 14:36:47.743 Detail, Node003, Removing current message
2018-12-04 14:36:47.743 Detail, Node003, Notification: ValueChanged
2018-12-04 14:36:48.682 Info, mgr,     Refreshing node 3: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2018-12-04 14:36:48.682 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x4d, 0xa8
2018-12-04 14:36:48.682 Info, Node003, Sending (Send) message (Callback ID=0x4d, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x4d, 0xa8
2018-12-04 14:36:48.691 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:36:48.691 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:36:48.707 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x4d, 0x00, 0x00, 0x03, 0xa5
2018-12-04 14:36:48.707 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x4d received (expected 0x4d)
2018-12-04 14:36:48.707 Info, Node003, Request RTT 24 Average Request RTT 24
2018-12-04 14:36:48.708 Detail,   Expected callbackId was received
2018-12-04 14:36:48.717 Detail, Node003,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x00, 0xd7
2018-12-04 14:36:48.718 Detail,
2018-12-04 14:36:48.718 Info, Node003, Response RTT 35 Average Response RTT 35
2018-12-04 14:36:48.718 Info, Node003, Received SwitchMultiLevel report: level=0
2018-12-04 14:36:48.718 Detail, Node003, Refreshed Value: old value=97, new value=0, type=byte
2018-12-04 14:36:48.718 Detail, Node003, Changes to this value are not verified
2018-12-04 14:36:48.718 Detail, Node003,   Expected reply and command class was received
2018-12-04 14:36:48.718 Detail, Node003,   Message transaction complete
2018-12-04 14:36:48.718 Detail, Node003, Removing current message
2018-12-04 14:36:48.719 Detail, Node003, Notification: ValueChanged
2018-12-04 14:36:49.684 Info, mgr,     Refreshing node 3: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2018-12-04 14:36:49.684 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x4e, 0xab
2018-12-04 14:36:49.684 Info, Node003, Sending (Send) message (Callback ID=0x4e, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x4e, 0xab
2018-12-04 14:36:49.693 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:36:49.693 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:36:49.708 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x4e, 0x00, 0x00, 0x02, 0xa7
2018-12-04 14:36:49.708 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x4e received (expected 0x4e)
2018-12-04 14:36:49.708 Info, Node003, Request RTT 23 Average Request RTT 23
2018-12-04 14:36:49.709 Detail,   Expected callbackId was received
2018-12-04 14:36:49.720 Detail, Node003,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x00, 0xd7
2018-12-04 14:36:49.720 Info, Node003, Response RTT 35 Average Response RTT 35
2018-12-04 14:36:49.720 Info, Node003, Received SwitchMultiLevel report: level=0
2018-12-04 14:36:49.720 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2018-12-04 14:36:49.720 Detail, Node003, Changes to this value are not verified
2018-12-04 14:36:49.720 Detail, Node003,   Expected reply and command class was received
2018-12-04 14:36:49.721 Detail, Node003,   Message transaction complete
2018-12-04 14:36:49.721 Detail, Node003, Removing current message
2018-12-04 14:36:49.721 Detail, Node003, Notification: ValueChanged
With Parameter 3 set to 3
2018-12-04 14:39:42.148 Info, Node003, Configuration::Set - Parameter=3, Value=3 Size=2
2018-12-04 14:39:42.148 Detail, Node003, Queuing (Send) ConfigurationCmd_Set (Node=3): 0x01, 0x0d, 0x00, 0x13, 0x03, 0x06, 0x70, 0x04, 0x03, 0x02, 0x00, 0x03, 0x25, 0x4f, 0xf8
2018-12-04 14:39:42.148 Info, Node003, Sending (Send) message (Callback ID=0x4f, Expected Reply=0x13) - ConfigurationCmd_Set (Node=3): 0x01, 0x0d, 0x00, 0x13, 0x03, 0x06, 0x70, 0x04, 0x03, 0x02, 0x00, 0x03, 0x25, 0x4f, 0xf8
2018-12-04 14:39:42.158 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:39:42.158 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:39:42.173 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x4f, 0x00, 0x00, 0x02, 0xa6
2018-12-04 14:39:42.173 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x4f received (expected 0x4f)
2018-12-04 14:39:42.173 Info, Node003, Request RTT 24 Average Request RTT 23
2018-12-04 14:39:42.173 Detail,   Expected callbackId was received
2018-12-04 14:39:42.173 Detail,   Expected reply was received
2018-12-04 14:39:42.173 Detail,   Message transaction complete
2018-12-04 14:39:42.173 Detail, Node003, Removing current message
2018-12-04 14:39:55.212 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2018-12-04 14:39:55.212 Detail, Node003, Refreshed Value: old value=255, new value=255, type=byte
2018-12-04 14:39:55.212 Detail, Node003, Changes to this value are not verified
2018-12-04 14:39:55.212 Detail, Node003, Notification: ValueChanged
2018-12-04 14:39:55.213 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 255
2018-12-04 14:39:55.213 Info, Node003, SwitchMultilevel::Set - Setting to level 255
2018-12-04 14:39:55.214 Info, Node003,   Duration: Default
2018-12-04 14:39:55.214 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0b, 0x00, 0x13, 0x03, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x50, 0xb2
2018-12-04 14:39:55.214 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x51, 0xb4
2018-12-04 14:39:55.220 Detail,
2018-12-04 14:39:55.220 Info, Node003, Sending (Send) message (Callback ID=0x50, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0b, 0x00, 0x13, 0x03, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x50, 0xb2
2018-12-04 14:39:55.229 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:39:55.229 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:39:55.254 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x50, 0x00, 0x00, 0x02, 0xb9
2018-12-04 14:39:55.254 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x50 received (expected 0x50)
2018-12-04 14:39:55.254 Info, Node003, Request RTT 34 Average Request RTT 28
2018-12-04 14:39:55.254 Detail,   Expected callbackId was received
2018-12-04 14:39:55.254 Detail,   Expected reply was received
2018-12-04 14:39:55.254 Detail,   Message transaction complete
2018-12-04 14:39:55.254 Detail, Node003, Removing current message
2018-12-04 14:39:55.255 Info, Node003, Sending (Send) message (Callback ID=0x51, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x51, 0xb4
2018-12-04 14:39:55.263 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:39:55.263 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:39:55.279 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x51, 0x00, 0x00, 0x02, 0xb8
2018-12-04 14:39:55.279 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x51 received (expected 0x51)
2018-12-04 14:39:55.279 Info, Node003, Request RTT 24 Average Request RTT 26
2018-12-04 14:39:55.279 Detail,   Expected callbackId was received
2018-12-04 14:39:55.290 Detail, Node003,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x00, 0xd7
2018-12-04 14:39:55.294 Detail,
2018-12-04 14:39:55.294 Info, Node003, Response RTT 39 Average Response RTT 37
2018-12-04 14:39:55.294 Info, Node003, Received SwitchMultiLevel report: level=0
2018-12-04 14:39:55.294 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2018-12-04 14:39:55.294 Detail, Node003, Changes to this value are not verified
2018-12-04 14:39:55.294 Detail, Node003,   Expected reply and command class was received
2018-12-04 14:39:55.294 Detail, Node003,   Message transaction complete
2018-12-04 14:39:55.295 Detail,
2018-12-04 14:39:55.295 Detail, Node003, Removing current message
2018-12-04 14:39:55.295 Detail, Node003, Notification: ValueChanged
2018-12-04 14:40:02.137 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2018-12-04 14:40:02.536 Detail, Node003, Refreshed Value: old value=255, new value=255, type=byte
2018-12-04 14:40:02.536 Detail, Node003, Changes to this value are not verified
2018-12-04 14:40:02.536 Detail, Node003, Notification: ValueChanged
2018-12-04 14:40:02.539 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 255
2018-12-04 14:40:02.539 Info, Node003, SwitchMultilevel::Set - Setting to level 255
2018-12-04 14:40:02.539 Info, Node003,   Duration: Default
2018-12-04 14:40:02.539 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0b, 0x00, 0x13, 0x03, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x52, 0xb0
2018-12-04 14:40:02.539 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x53, 0xb6
2018-12-04 14:40:02.552 Detail,
2018-12-04 14:40:02.553 Info, Node003, Sending (Send) message (Callback ID=0x52, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0b, 0x00, 0x13, 0x03, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x52, 0xb0
2018-12-04 14:40:02.561 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:40:02.561 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:40:02.577 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x52, 0x00, 0x00, 0x02, 0xbb
2018-12-04 14:40:02.577 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x52 received (expected 0x52)
2018-12-04 14:40:02.577 Info, Node003, Request RTT 24 Average Request RTT 25
2018-12-04 14:40:02.577 Detail,   Expected callbackId was received
2018-12-04 14:40:02.577 Detail,   Expected reply was received
2018-12-04 14:40:02.577 Detail,   Message transaction complete
2018-12-04 14:40:02.578 Detail,
2018-12-04 14:40:02.578 Detail, Node003, Removing current message
2018-12-04 14:40:02.578 Info, Node003, Sending (Send) message (Callback ID=0x53, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x53, 0xb6
2018-12-04 14:40:02.586 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-04 14:40:02.586 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2018-12-04 14:40:02.602 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x53, 0x00, 0x00, 0x02, 0xba
2018-12-04 14:40:02.602 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x53 received (expected 0x53)
2018-12-04 14:40:02.602 Info, Node003, Request RTT 24 Average Request RTT 24
2018-12-04 14:40:02.602 Detail,   Expected callbackId was received
2018-12-04 14:40:02.613 Detail, Node003,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x00, 0xd7
2018-12-04 14:40:02.613 Info, Node003, Response RTT 35 Average Response RTT 36
2018-12-04 14:40:02.613 Info, Node003, Received SwitchMultiLevel report: level=0
2018-12-04 14:40:02.613 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2018-12-04 14:40:02.614 Detail, Node003, Changes to this value are not verified
2018-12-04 14:40:02.614 Detail, Node003,   Expected reply and command class was received
2018-12-04 14:40:02.614 Detail, Node003,   Message transaction complete
2018-12-04 14:40:02.614 Detail, Node003, Removing current message
2018-12-04 14:40:02.614 Detail, Node003, Notification: ValueChanged
Appreciate any assistance. I might just have to go and get a momentary switch if I can’t sort it out
