Has anyone been able to integrate an aircon unit on HA with the Philips Dynalite Antumbra display?
I’m hoping to control my aircon using HA via the Antumbra display.
Hi Matt,
A couple of questions to maybe assist:
I am presuming that the Aircon is already configured in your system builder and can be controlled via your Antumbra display?
What type of Aircon are you using and what communication protocol are you using between Dynalite and the aircon?
Cheers,
Gareth
I’ve actually created a dummy aircon on the Antumbra. Then I used https://github.com/matthew-larner/philips-dynalite-mqtt and Node Red to tie them all together. This repo isn’t documented yet, but I can update the docs if you think you might benefit.
I’m using Daikin and Mitsubishi which both work. What aircon type are you using?
Did it the same way, expect no node-red just automations.
Created dummy areas and switches in Dynalite, and then made automations which recognize dynalite commands to change SmartIR - Broadlink IR controlled. Works great.
Hey guys, any updates on how we can show Philips Dynalite AC temp, set temp and modes on HA?
Manage to integrate Dynalite AC room temperature reading into Home Assistant using TCP client connection in Node-red (interactive). It took me sometime but finally done it with all the hard coding, debugging and testing. Here is my Home Assistant (UI) integration to Philips Dynalite AC (DDFCU & Antumbra) using Node-red as interface (TCP socket). Both bi-directional and interactive (Antumbra-keypad & Home Assistant-UI).
Hello, sir. Is it possible to get a JSON file to configure myself (for example)?
