LOG
2020-09-03 21:57:03 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds
2020-09-03 21:57:05 INFO (MainThread) [homeassistant.setup] Setting up recorder
2020-09-03 21:57:05 INFO (MainThread) [homeassistant.setup] Setting up http
2020-09-03 21:57:05 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds
2020-09-03 21:57:05 INFO (MainThread) [homeassistant.setup] Setting up system_log
2020-09-03 21:57:05 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds
2020-09-03 21:57:06 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.6 seconds
2020-09-03 21:57:06 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {‘api’, ‘system_log’, ‘auth’, ‘http’, ‘lovelace’, ‘hassio’, ‘device_automation’, ‘frontend’, ‘webhook’, ‘cloud’, ‘alexa’, ‘websocket_api’, ‘onboarding’, ‘person’, ‘search’, ‘config’}
2020-09-03 21:57:06 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2020-09-03 21:57:07 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2020-09-03 21:57:07 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds
2020-09-03 21:57:07 INFO (MainThread) [homeassistant.setup] Setting up person
2020-09-03 21:57:07 INFO (MainThread) [homeassistant.setup] Setting up api
2020-09-03 21:57:07 INFO (MainThread) [homeassistant.setup] Setting up auth
2020-09-03 21:57:07 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds
2020-09-03 21:57:07 INFO (MainThread) [homeassistant.setup] Setting up hassio
2020-09-03 21:57:07 INFO (MainThread) [homeassistant.setup] Setting up webhook
2020-09-03 21:57:07 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds
2020-09-03 21:57:08 INFO (MainThread) [homeassistant.setup] Setting up alexa
2020-09-03 21:57:08 INFO (MainThread) [homeassistant.setup] Setup of domain alexa took 0.0 seconds
2020-09-03 21:57:08 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2020-09-03 21:57:08 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds
2020-09-03 21:57:08 INFO (MainThread) [homeassistant.setup] Setting up config
2020-09-03 21:57:09 INFO (MainThread) [homeassistant.setup] Setup of domain api took 1.9 seconds
2020-09-03 21:57:09 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 2.1 seconds
2020-09-03 21:57:09 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.2 seconds
2020-09-03 21:57:09 INFO (MainThread) [homeassistant.setup] Setting up search
2020-09-03 21:57:09 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2020-09-03 21:57:09 INFO (SyncWorker_4) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2020-09-03 21:57:09 INFO (SyncWorker_3) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2020-09-03 21:57:09 INFO (SyncWorker_2) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2020-09-03 21:57:12 INFO (MainThread) [homeassistant.setup] Setting up cloud
2020-09-03 21:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain person took 5.7 seconds
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.7 seconds
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds
2020-09-03 21:57:13 INFO (SyncWorker_4) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setting up frontend
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 6.5 seconds
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {‘mobile_app’, ‘sun’, ‘input_datetime’, ‘sonos’, ‘automation’, ‘dynalite’, ‘ssdp’, ‘history’, ‘input_boolean’, ‘input_text’, ‘input_number’, ‘scene’, ‘logbook’, ‘zeroconf’, ‘tts’, ‘group’, ‘default_config’, ‘script’, ‘system_health’, ‘map’, ‘met’, ‘input_select’, ‘updater’, ‘upnp’, ‘zone’}
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setting up sun
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.2 seconds
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setting up automation
2020-09-03 21:57:13 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up dynalite
2020-09-03 21:57:14 DEBUG (MainThread) [homeassistant.components.dynalite] Setting up dynalite component config = OrderedDict([(‘bridges’, [OrderedDict([(‘host’, ‘192.168.0.200’), (‘port’, 50000), (‘autodiscover’, True), (‘polltimer’, 1.0), (‘name’, ‘dynalite’), (‘active’, False)])])])
2020-09-03 21:57:14 DEBUG (MainThread) [homeassistant.components.dynalite] Starting config entry flow host=192.168.0.200 conf=OrderedDict([(‘host’, ‘192.168.0.200’), (‘port’, 50000), (‘autodiscover’, True), (‘polltimer’, 1.0), (‘name’, ‘dynalite’), (‘active’, False)])
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain dynalite took 0.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up input_text
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up input_number
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up scene
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up group
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up script
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up met
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up input_select
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up updater
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up zone
2020-09-03 21:57:14 DEBUG (MainThread) [homeassistant.components.dynalite] Starting async_step_import - OrderedDict([(‘host’, ‘192.168.0.200’), (‘port’, 50000), (‘autodiscover’, True), (‘polltimer’, 1.0), (‘name’, ‘dynalite’), (‘active’, False)])
2020-09-03 21:57:14 DEBUG (MainThread) [homeassistant.components.dynalite] Setting up entry OrderedDict([(‘host’, ‘192.168.0.200’), (‘port’, 50000), (‘autodiscover’, True), (‘polltimer’, 1.0), (‘name’, ‘dynalite’), (‘active’, False)])
2020-09-03 21:57:14 DEBUG (MainThread) [dynalite_devices_lib] bridge async_configure - {‘name’: ‘dynalite’, ‘host’: ‘192.168.0.200’, ‘port’: 50000, ‘autodiscover’: True, ‘polltimer’: 1.0, ‘active’: ‘off’}
2020-09-03 21:57:14 DEBUG (MainThread) [homeassistant.components.dynalite] Setting up bridge - host 192.168.0.200
2020-09-03 21:57:14 DEBUG (MainThread) [dynalite_devices_lib] bridge async_setup
2020-09-03 21:57:14 DEBUG (MainThread) [dynalite_devices_lib] Connecting to Dynet on 192.168.0.200:50000
2020-09-03 21:57:14 INFO (SyncWorker_3) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up history
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.7 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up logbook
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up system_health
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setting up map
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 1.0 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 0.8 seconds
2020-09-03 21:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 0.8 seconds
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 1.2 seconds
2020-09-03 21:57:15 INFO (SyncWorker_1) [homeassistant.loader] Loaded weather from homeassistant.components.weather
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 1.1 seconds
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.8 seconds
2020-09-03 21:57:15 INFO (SyncWorker_3) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setting up weather
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 0.0 seconds
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 1.4 seconds
2020-09-03 21:57:15 DEBUG (MainThread) [dynalite_devices_lib] handle_event - type=CONNECTED event=None
2020-09-03 21:57:15 DEBUG (MainThread) [dynalite_devices_lib] Received CONNECTED message
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.components.dynalite] Connected to dynalite host
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setting up tts
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.components.weather] Setting up weather.met
2020-09-03 21:57:15 INFO (SyncWorker_1) [homeassistant.loader] Loaded switch from homeassistant.components.switch
2020-09-03 21:57:15 INFO (SyncWorker_5) [homeassistant.loader] Loaded cover from homeassistant.components.cover
2020-09-03 21:57:15 INFO (SyncWorker_3) [homeassistant.loader] Loaded light from homeassistant.components.light
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.updater
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setting up sonos
2020-09-03 21:57:15 INFO (MainThread) [homeassistant.setup] Setup of domain sonos took 0.0 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setting up upnp
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.6 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setting up switch
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setting up cover
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 0.0 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setting up light
2020-09-03 21:57:16 INFO (SyncWorker_4) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain upnp took 0.3 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.components.switch] Setting up switch.dynalite
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.components.cover] Setting up cover.dynalite
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.2 seconds
2020-09-03 21:57:16 DEBUG (MainThread) [homeassistant.components.dynalite] Setting up switch entry = OrderedDict([(‘host’, ‘192.168.0.200’), (‘port’, 50000), (‘autodiscover’, True), (‘polltimer’, 1.0), (‘name’, ‘dynalite’), (‘active’, False)])
2020-09-03 21:57:16 DEBUG (MainThread) [homeassistant.components.dynalite] Setting up cover entry = OrderedDict([(‘host’, ‘192.168.0.200’), (‘port’, 50000), (‘autodiscover’, True), (‘polltimer’, 1.0), (‘name’, ‘dynalite’), (‘active’, False)])
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setting up notify
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds
2020-09-03 21:57:16 INFO (SyncWorker_1) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.components.light] Setting up light.dynalite
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.mobile_app
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.6 seconds
2020-09-03 21:57:16 DEBUG (MainThread) [homeassistant.components.dynalite] Setting up light entry = OrderedDict([(‘host’, ‘192.168.0.200’), (‘port’, 50000), (‘autodiscover’, True), (‘polltimer’, 1.0), (‘name’, ‘dynalite’), (‘active’, False)])
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setting up media_player
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.1 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setting up sensor
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.sonos
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mobile_app
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 0.1 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 1.1 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.mobile_app
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds
2020-09-03 21:57:16 INFO (MainThread) [homeassistant.components.updater] Submitted analytics to Home Assistant servers. Information submitted includes {}
2020-09-03 21:57:20 INFO (MainThread) [homeassistant.setup] Setting up default_config
2020-09-03 21:57:20 INFO (SyncWorker_16) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2020-09-03 21:57:21 INFO (MainThread) [homeassistant.setup] Setting up stream
2020-09-03 21:57:21 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.1 seconds
2020-09-03 21:57:21 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.9 seconds
2020-09-03 21:57:26 INFO (MainThread) [homeassistant.components.upnp] No UPnP/IGD devices discovered
2020-09-03 21:57:26 INFO (MainThread) [homeassistant.components.upnp] Unable to create UPnP/IGD, aborting
2020-09-03 21:57:26 WARNING (MainThread) [homeassistant.config_entries] Config entry for upnp not ready yet. Retrying in 5 seconds
2020-09-03 21:57:26 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 23.27s
2020-09-03 21:57:26 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2020-09-03 21:57:26 INFO (SyncWorker_0) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2020-09-03 21:57:26 INFO (MainThread) [homeassistant.core] Timer:starting
2020-09-03 21:57:27 INFO (SyncWorker_20) [homeassistant.loader] Loaded spotify from homeassistant.components.spotify
2020-09-03 21:57:41 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.upnp
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet ac:04:88:dc:00:29:aa:55 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 04:88:dc:00:29:aa:55:55 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 88:dc:00:29:aa:55:55:00 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet dc:00:29:aa:55:55:00:02 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 00:29:aa:55:55:00:02:ff - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 29:aa:55:55:00:02:ff:ff - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet aa:55:55:00:02:ff:ff:ff - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 55:55:00:02:ff:ff:ff:03 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 55:00:02:ff:ff:ff:03:09 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 00:02:ff:ff:ff:03:09:20 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 02:ff:ff:ff:03:09:20:04 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet ff:ff:ff:03:09:20:04:2f - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet ff:ff:03:09:20:04:2f:c0 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet ff:03:09:20:04:2f:c0:ac - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 03:09:20:04:2f:c0:ac:04 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 09:20:04:2f:c0:ac:04:88 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 20:04:2f:c0:ac:04:88:dc - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 04:2f:c0:ac:04:88:dc:00 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet 2f:c0:ac:04:88:dc:00:29 - moving one byte forward
2020-09-03 21:58:00 DEBUG (MainThread) [dynalite_devices_lib] Unable to process packet c0:ac:04:88:dc:00:29:aa - moving one byte forward
