you should be able to add a card in Lovelace to do so
Hi everyone,
Real noob here to this.
I have been wanting to setup Dynalite through Google Home for quite some time. What’s my easiest method of setup? I tried setting up Hass.io on my local PC but struggled, will i need to purchase a raspberry pi?
thanks guys
I set up my hassio on a spare PC, you can follow the YouTube instruction here
Thanks! I have got to the point of trying to add devices using auto discover but am missing something. Can anyone help?
Is this only possible with a bridge in between the dynalite gateway and router?
Yes you need a bridge, If you have already the PDEG then use it. Otherwise you need to buy the one @uzelac referred to or similar
Okay I already have the envision gateway setup and have previously used the app but am wanting to intergrate google home?
For google assistant integration check this link
There is a switch, boolean if i rememver correctly in config which you need to toggle to true and it will work.
It’s a bit laggy but it works.
active and pooltimer
BTW.
If you have IP -> RS485 gateway, that is all the hardware you need to connect with Dynalite software…
Thank you, I have checked it and as you said it is laggy. about Dynalite software I always get bad packet in the log. Sometimes it gives the correct packet. If you have tried a gateway that works please let me know or maybe my configuration is not correct, I have posted my configuration up if you would like to take a look.
Thank you
I dont have any issues with EP, it is easier with PDEG but still works with 10x cheaper IP-485 gateway.
Is it still laggy? I’m in the process of building and need to choose between Dynalite and C-bus. I’m hoping that Dynalite will be nice and fast with HA
Yes, it is still laggy, I purchased another bridge and I will check if the issue is for that. It wont update the states as expected when the button is pushed physically.
Hey All,
I’m finding that several times I’ve got to tell hass the same command twice for it to respond, then once it’s “awake” it’s fine do you know if any poll or keep alive parameters to stop this as in hass loveface cards or on google home using nabu casa it just doesn’t respond first go, second go and for a couple of hours fine then goes sleeping again
Ta
Nick
What are you using for your IP-485 gateway?
I have both chinese i recommended and genuine Philips.
No difference, both work the same.
Can you please share the configuration on the Chinese 485 bridge
I’ve just setup the PDEG and it works for turning lights on/off from HA with no latency. The issue I’ve got is that when you change a light status from a physical switch, it doesn’t update the status in HA.
Does this happen for you or do you get 2-way sync?
