Philips Go - Not pairing with Z2MQTT
  • I have a brand new (never paired) Philips Go 2.0 (I believe it’s this particular model - could be wrong Philips 7602031P7 control via MQTT | Zigbee2MQTT):
  • I have a Sonoff 3.0 Dongle, flashed recent firmware. Using Zigbee2MQTT.
  • However, it fails to pair as “Permit all” or forced onto a particular device.
  • Touchlink function doesn’t work, it crashes my Zigbee network if I use Touchlink.
Any idea what I might be doing wrong?
Logs:
Info <small>2022-07-04 21:46:10</small>`Removing device '0x001788010b4b59a6' (block: false, force: true)`
Info <small>2022-07-04 21:46:10</small>`MQTT publish: topic 'zigbee2mqtt/0x001788010b4b59a6', payload ''`
Info <small>2022-07-04 21:46:10</small>`Successfully removed device '0x001788010b4b59a6' (block: false, force: true)`
Info <small>2022-07-04 21:46:10</small>`MQTT publish: topic 'zigbee2mqtt/bridge/response/device/remove', payload '{"data":{"block":false,"force":true,"id":"0x001788010b4b59a6"},"status":"ok","transaction":"y93ds-1"}'`
Info <small>2022-07-04 21:46:21</small>`MQTT publish: topic 'zigbee2mqtt/TV Plug', payload '{"energy":47.04,"linkquality":149,"power":140,"state":"ON"}'`
Info <small>2022-07-04 21:46:47</small>`MQTT publish: topic 'zigbee2mqtt/Dining Hue Switch', payload '{"action":null,"battery":91.5,"linkquality":80,"update":{"state":"available"},"update_available":null}'`
Info <small>2022-07-04 21:46:47</small>`Update available for 'Dining Hue Switch'`
Info <small>2022-07-04 21:46:48</small>`Zigbee: allowing new devices to join via TV Plug.`
Info <small>2022-07-04 21:46:48</small>`MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"device":"TV Plug","time":254,"value":true},"status":"ok","transaction":"y93ds-2"}'`
Info <small>2022-07-04 21:46:59</small>`MQTT publish: topic 'zigbee2mqtt/Master Bedroom Plug', payload '{"linkquality":134,"power_on_behavior":null,"state":"ON","update":{"state":"available"},"update_available":true}'`
Info <small>2022-07-04 21:47:22</small>`Device '0x001788010b4b59a6' joined`
Info <small>2022-07-04 21:47:22</small>`MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x001788010b4b59a6","ieee_address":"0x001788010b4b59a6"},"type":"device_joined"}'`
Info <small>2022-07-04 21:47:22</small>`Starting interview of '0x001788010b4b59a6'`
Info <small>2022-07-04 21:47:22</small>`MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x001788010b4b59a6","ieee_address":"0x001788010b4b59a6","status":"started"},"type":"device_interview"}'`
Error <small>2022-07-04 21:49:40</small>`Failed to interview '0x001788010b4b59a6', device has not successfully been paired`
Info <small>2022-07-04 21:49:41</small>`MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x001788010b4b59a6","ieee_address":"0x001788010b4b59a6","status":"failed"},"type":"device_interview"}'`
Info <small>2022-07-04 21:49:57</small>`Starting interview of '0x001788010b4b59a6'`
Info <small>2022-07-04 21:49:58</small>`MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x001788010b4b59a6","ieee_address":"0x001788010b4b59a6","status":"started"},"type":"device_interview"}'`
Info <small>2022-07-04 21:50:04</small>`MQTT publish: topic 'zigbee2mqtt/Kitchen Light Switch', payload '{"action":null,"device_temperature":25,"flip_indicator_light":null,"illuminance":0,"illuminance_lux":0,"led_disabled_night":null,"linkquality":145,"mode_switch":null,"operation_mode":null,"power_outage_count":9,"power_outage_memory":null,"state":"OFF","temperature":23}'`
Info <small>2022-07-04 21:50:17</small>`MQTT publish: topic 'zigbee2mqtt/TV Plug', payload '{"energy":47.04,"linkquality":145,"power":131,"state":"ON"}'`
Info <small>2022-07-04 21:50:44</small>`MQTT publish: topic 'zigbee2mqtt/TV Plug', payload '{"energy":47.05,"linkquality":145,"power":131,"state":"ON"}'`
