i bought a 3 pack of the Philips Hue A19.
I’m running HA on a HA-Blue with a ZZH! stick, so no hue bridge.
2 out of the 3 lights are immediately discovered and added to HA, but the 3e one is not seen.
Does someone have the same issue, or experienced the same ?
Common scenario is Zigbee Coordinator USB adapter has bad reception due to interference if not following the best practice guidelines, which especially includes using a long shielded USB extension cable to a USB 2.0 port or via a powered USB 2.0 hub (and not a USB 3.0 port as those are infamous for causing interference). → https://github.com/zigpy/zigpy/wiki/Generic-best-practice-tips-on-improving-Zigbee-network-range-and-general-stability After following all those best practices, perform a factory reset of that device (which will unpair it and restore it to factory default settings) and then try to join/pair it again to the ZHA integration which will start the interview process again.
Thank you for the reply.
For testing purposes i put them in the same spot, thats confirmed to be good, when pairing to avoid most of the issues written in that article.
Like i said 2 were found instantaneously, the other never shows up.
I dont know how to reset the bulb to factory settings as i have 0 other hue products
