I have an Philips Hue Aurelle lamp with warm and cold white.
I just installed an Shelly RGB2 module in it and found that it had green light as well as the warm and cold white.
Have anyone experienced warm and cold white lamps with green or have any good idea about why the lamp has green light?
Maybe it is closer to daylight with some green?
The lamp has 3 wires that gives green, cold white and warm white light, so assume it has green LEDs.
I only opened the top where the zigbee module is installed and replaced it with Shelly RGB2. Didn’t open the part that the LEDs are installed in, sorry.
The green is a yellowish-green as you could see on the picture.
