Philips Hue automation trigger 404 error
Hi
This is about an automation, which is created in the Hue app and should be deactivated or activated by an automation in Home Assistant. The automation in Home Assistant is not part of this topic.
I can see an entity for the Hue automation, which are directly configured in the bridge. It is displayed as a switch in the entities (“switch.automation_automationtest”). I can see the status once I create the automation. Trying to toggle it results in a 404 error: Request failed due connection error: 404, message='Not Found', url=URL('https://192.168.xx.xx/clip/v2/resource/motion/277d65a7-5bcc-4fce-96e5-9c74a44a7bf4
So, does someone have an idea how this switch can be populated by the integration, but not toggled?
I just saw your post when searching. I swear I used to be able to toggle mine, but a recent update might have broken it.
