Hey folks. I’ll raise a bug too, but I was wondering if anyone else had seen the same thing?
Since installing 2021.12, I’ve been getting the below error(s) when triggering my automations to turn on the lights. Other errors are similar, but include different scripts that were called and different Hue api v2 URLS.
Thanks in advance … hoping it’s not just me! haha.
Logger: homeassistant.components.script.turn_on_hallway_lights
Source: components/hue/bridge.py:132
Integration: Scripts (documentation, issues)
First occurred: 7:03:51 am (1 occurrences)
Last logged: 7:03:51 am
Turn on the Hallway Lights: Error executing script. Unexpected error for call_service at pos 1: 400, message='Bad Request', url=URL('https://192.168.1.72/clip/v2/resource/light/e5b94e29-18ef-4f3d-ad1e-63b7df075b40')
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 381, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 584, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1495, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1530, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 209, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 663, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 896, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 700, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 494, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/hue/v2/group.py", line 175, in async_turn_on
await self.bridge.async_request_call(
File "/usr/src/homeassistant/homeassistant/components/hue/bridge.py", line 132, in async_request_call
return await task(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/aiohue/v2/controllers/lights.py", line 85, in set_state
await self._send_put(id, update_obj)
File "/usr/local/lib/python3.9/site-packages/aiohue/v2/controllers/base.py", line 137, in _send_put
await self._bridge.request("put", endpoint, json=data)
File "/usr/local/lib/python3.9/site-packages/aiohue/v2/__init__.py", line 152, in request
async with self.create_request(method, path, **kwargs) as resp:
File "/usr/local/lib/python3.9/contextlib.py", line 181, in __aenter__
return await self.gen.__anext__()
File "/usr/local/lib/python3.9/site-packages/aiohue/v2/__init__.py", line 182, in create_request
res.raise_for_status()
File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 1004, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 400, message='Bad Request', url=URL('https://192.168.1.72/clip/v2/resource/light/e5b94e29-18ef-4f3d-ad1e-63b7df075b40')
