I have two Philips Hue bulbs, the box is labelled with “white and color ambiance” and “800”.
Pairing the bulbs with Conbee was easy. However, in Home Assistant I just get a plain on-off switch, with no possibility to adjust the brightness or the color.
I specifically bought this bulb because I saw it listed as compatible on the Conbee II web page.
So my questions are:
- Did I miss a step with the pairing, or does it need to be done in a special way ?
- Is some extra configuration required ?
- Or did I somehow get the wrong bulbs ? If I did, what would be the right ones ?
Update: It does work. The problem is that by default a “button” instead of a “light” card is added.
