Philips Hue bulbs Time-based light colour/natural light
Good evening,
I currently have a Philips Hue Bridge with Philips Hue White & Color E27 Zigbee bulbs + dimmer switch (old gen) + 2x Hue motion sensors.
And I would like to have cold white light during the day and yellow/warm light in the evening. Regardless of whether I switch on the light via Alexa (Echo 4) on the dimmer switch or via the Home Assistant app.
I currently have the “Time-based light” via the Philips Hue app at Hue Labs and the “Natural Light” on the motion sensor.
What I want works there but only via the motion sensor. Using Alexa or the Home Assistant app, it’s still always cool white light in the evening.
Is there a way to do this?
I would appreciate an answer, thank you
“Home Assistant Operating System” latest version runs directly on a Raspberry Pi 4B 4GB
And I have the CC2652P Sonoff ZigBee 3.0 USB Stick with ZigBee2mqtt
Does nobody know a solution?
Hi
did you ever work this out ?
check out the “adaptive lighting” custom component in HACS - it should do exactly what you want (and then some)
