Philips hue controling temperature of 2 spotlights together
Hi all,
in developer Tools i see my entity “spotjes” which is a combination of 2 spotlights.
[light.spotjes]
on
min_mireds: 153
max_mireds: 500
effect_list: colorloop,random brightness: 252
color_temp: 373
is_hue_group: true friendly_name: spotjes
supported_features: 63
in Developer Tools when I click the “i” I can change the color temperature,
but when I create a card and use that entity, I can only control the color_temp of each spotlight separately. Am i missing how I can control color temp of both together through lovelace ui or do I have to start diving in the config file?
thanks !
Tom
If you add them to a zone in the Hue app, then they should show up as a single light in Lovelace. I believe you should be able to control the color temp of both spotlights using this method.
You might be able to do it as well with a “light group” group, but I’m not sure if it supports color temp in Lovelace.
Oh my… I was searching way to far… Just add"lamp" card and add that entity…
Thanks mate.
Any easy way to have a temperature slider card?
This is what I use. Works a treat!
