Philips Hue dial Switch music and light remote
Hi i found this
https://flows.nodered.org/flow/c95d562d4858cbe1bf80fee95ba9815f#
and thats impressive. To my fault, i dont get it to work with my ZHA Hue tap dial events. I used
to get the buttons and the wheel.
After some trying, i got the 3 Buttons (1-3 dots) to the right nodes. As you can see below, i got my own “hue tap dial” subflow. It has 6 exits,
up
down
click
doubleclick
trippleclick
else
on port 3 i have a switch that gives me the button 1-4 when only clicked one time. I also tried the wheelup and wheeldown exits to put on the same nodes when coming from the “sort_input”.
But i still cant get, where to set the modes with button 4 pressed.
As you can see, i left the deconz nodes inside and untouched, because i dont know how to configure them the right way.
So can someone give me a clue, how to set up the nodes to get this working?
greetins Vala
Hello, have you progress in your flow?
I want also this same one but with Zigbee2qtt.
I find a way to use button for music (Pause/play, Next Track, prévious Track), Light (Brightness and Temperature color by dial).
BUT don’t find a way to implement double clic, triple clic :frowning:
