Philips Hue Dimmer Switch - ghost reports
few hours ago i started getting ghost reporting from HA on Philips Hue Dimmer Switch “hue events”.
the log shows button press thought no one touched the dimmer switch.
i have 4 of these dimmer switches and i love’em, each can preform up to 8 different “triggers”, when they r configured via HA and not the philips app.
so far:
i replaced the battery (was showing 66%), but thats not it.
reset the Philips Hue Dimmer Switch
restarted HA and the philips hub
anyone?
It is a known issue with the latest Hue firmware update: Hue switches triggering automation by itself after first initial trigger · Issue #53177 · home-assistant/core · GitHub
hey thanks!
i saw the thread.
can i tribute in anyway? run more tests, supply more data or anything?
i’ll be happy to assist if i can
@tennbaum - have you managed to get the eight different triggers working? The only one that works for me is “Turn on button released”.
hell yea.
that is why this dimmer is the best “button” ever.
be sure to use the dimmer as “Device” in “trigger automation”
so:
trigger type: Device
Device: “the name of your hue dimmer switch”
Trigger:
here you will get a drop down with 9 options:
the first is “battery level changes”
the other 8 are:
“Turn on” button released
“Turn on” button released after long press
“Dim up” button released
“Dim up” button released after long press
and so on.
hit me back if you need anymore help with this
Are you using the V2 dimmer (the one with “Hue” on the front)? For me, the only option that does anything is “turn on button released”, which works like a simple toggle button. Fortunately, that’s all I need it to do.
The issue has been closed on Github, so I assume a fix will be in the next HA release (on Wednesday?).
i hope/guess so…
if im not mistaken there were 2 threads that were merged, and solved.
is there a way to implament the “fix” any sooner?
my dimmer is the “old” generation, without the “hue” logo on the front.
you have the newer version, and all i have described is not relevant for it anymore?
i took a snapshot to better explain what i see onscreen:
That’s still correct for the V2 version. It just doesn’t seem to work (yet?) :roll_eyes:
weird.
did you came across others with similar problem on the v2 dimmer switch? is that a well known vast problem with this device, or its just weird thing that is on your end only?
I’m probably just confused by all the random switching on and off - I’ll test again when that’s fixed. The fix is in the next update, apparently:
you need to remember that with the ha configuration, there is no “off” anymore. just two different triggers- “button released after short, or, long press”
meaning:
  1. “press and release”,
  2. “press, hold *, and release”
  • (hold for about 2 sec - you can release after the small led on the deimmer blinked for the second time)
“dimm up”, “dimm down”, “on” and “off” are just “buttons” in a row for HA. each can preform whatever 2 tasks you like (‘short’ press and ‘2 sec’ press)
hope this is clear enough and helpful
cheers
This issue intrigued me so I created an automation to detect hue_event and report it as a persistent_notification. So far, the only events that have been reported are the real ones produced when I operate the dimmer-switch and no “ghost” events. Tested with 2021.7.2 and first model of Philips Hue Dimmer Switch.
- alias: Monitor Hue Dimmer Switch Events
  - platform: event
    event_type: hue_event
  - service: notify.persistent_notification
      title: 'Hue Event {{ now().timestamp() | timestamp_local }}'
      message: >
        {% set buttons = {1:'ON', 2:'INCREASE', 3:'DECREASE', 4:'OFF'} %}
        {% set events = {0:'press', 1:'hold', 2:'release', 3:'hold_release'} %}
        {% set event = trigger.event.data.event | int %}
        {% set b = event // 1000 %}
        {% set e = event % 1000 %}
        id: {{ trigger.event.data.id }},
        button: {{ buttons[b] if b in buttons.keys() else 'UNKNOWN' }},
        event: {{ events[e] if e in events.keys() else 'unknown'}} ({{ event }})
  mode: queued
Sample output after pressing ON then OFF.
Using your excellent code (how do you knock it out so fast? :wink:) I get similar results:
However, only the top two were the result of a button press. The kitchen dimmer switch event appears to have been triggered by a motion sensor detecting movement.
The practical effect is that the bathroom light goes on and off every 10 minutes or so.
The implication is that the Hue integration may be misreporting the motion-sensor event as a switch-button event?
Unfortunately, I can’t test that scenario because I don’t have a Hue motion sensor.
I think so. I’ve been out of the house for the last half hour (walking the dog :roll_eyes:) and there are now a couple more:
The kitchen one is me coming back in, but I’ve no idea where the bathroom one comes from. The light is now off.
@tennbaum Do you have motion sensors?
i do.
3 of them.
the light sensor became very unresponsive (could take up to 2m to update), but motion and temp works good.
Looks like that’s it.
If movement in view of a motion sensor is reported as a button-action event then that’s obviously incorrect.
My automation doesn’t report all of the event data that’s available, only what I believed to be most important namely id (the device’s name) and event (a four-digit number). Maybe there’s something else in the event’s data (although I doubt it) that is also included when the event is produced by the motion sensor (versus the dimmer-switch).
To be certain, I suggest you use Developer Tools > Events to inspect the actual hue_event messages generated when the motion sensor reports motion.
Screenshot from 2021-07-31 13-46-21
Click ‘Start Listening’ and then move in front of the motion sensor. The event data will be displayed in JSON format. I predict the data will look exactly the same as what a button-action produces, which means there’s a bug in the integration.
hey man
was trying to help, but for some strange reason the motion sensors do not registar as “hue_event”.
just to check, i tried the dimmer switch - and it does.
i put * and got you the reporting of the sensor:
“event_type”: “state_changed”,
“data”: {
“entity_id”: “sensor.hue_motion_sensor_1_light_level”,
“old_state”: {
“state”: “13.0”,
“attributes”: {
“state_class”: “measurement”,
“battery_level”: 100,
“lightlevel”: 11142,
“daylight”: false,
“dark”: true,
“threshold_dark”: 26768,
“threshold_offset”: 7000,
“unit_of_measurement”: “lx”,
“friendly_name”: “kitchen light level”,
“device_class”: “illuminance”
“last_changed”: “2021-07-31T18:28:48.028454+00:00”,
“last_updated”: “2021-07-31T18:28:48.028454+00:00”,
“context”: {
“id”: “8c3bad55a592417750c30da93dae9e58”,
“parent_id”: null,
“user_id”: null
“new_state”: {
“state”: “22.92”,
“attributes”: {
“lightlevel”: 13604,
“daylight”: false,
“dark”: true,
“last_changed”: “2021-07-31T18:28:53.019733+00:00”,
“last_updated”: “2021-07-31T18:28:53.019733+00:00”,
“context”: {
“id”: “90cfb82bc234878dbbc28d7a771457ba”,
“parent_id”: null,
“user_id”: null
“origin”: “LOCAL”,
“time_fired”: “2021-07-31T18:28:53.019733+00:00”,
“context”: {
“parent_id”: null,
“user_id”: null
defiantly not registering as the dimmer switch - hope this help
