Hi! I’m new to Home assistant and I’ve been testing Hue lights in one of the rooms to be sure everything works fine before I transfer the rest of the Hue stuff from Hue hub to Home assistant. I have started by adding one Hue light bulb and Hue dimmer switch v2 via Zigbee. I have setup a simple ON/OFF automation as you can see here:
The thing is that the switch is very often unresponsive. It takes a few presses to the on/off button on the Hue switch to actually get the light to turn/on. Once the light is on, the switch stays responsive but after some time it will become unresponsive again. It’s like something went to standby mode and then it takes a few nudges to wake up again. Does anyone have any idea what might be the issue?
I run HA on Raspberry PI 4B 8GB and I use SkyConnect.
