Unfortunately I found this automation quite buggy. It would require multiple presses to trigger the action, with a very high failure rate and sometimes it would take seconds to trigger it (same result with - and with _. For me it made no difference). I think the problem was it was quite cpu-intensive. I rewrote it for anyone interested to try it. At least for me it works flawlessly now.
EDIT: Just noticed I was using your V1. I didn’t try V2.
gist here
blueprint:
name: Philips Hue Dimmer Switch control
description: 'Control lights with a Philips Hue Dimmer Switch. Set an action for each button. Note: You have to pick an action for each event. If you don’t want to react to an event, choose a Delay of 0sec.'
domain: automation
input:
remote:
name: Dimmer Switch Action sensor
description: Select your entity that will control this
automation.
selector:
entity:
domain: sensor
action_on-press:
description: select action to run when you press I
default: []
selector:
action: {}
action_off-press:
description: select action to run when you press O
default: []
selector:
action: {}
action_up-press:
description: select action to run when you press UP
default: []
selector:
action: {}
action_down-press:
description: select action to run when you press DOWN
default: []
selector:
action: {}
action_on-hold:
description: select action to run when you hold I
default: []
selector:
action: {}
action_off-hold:
description: select action to run when you hold O
default: []
selector:
action: {}
action_up-hold:
description: select action to run when you hold UP
default: []
selector:
action: {}
action_down-hold:
description: select action to run when you hold DOWN
default: []
selector:
action: {}
mode: restart
- platform: state
entity_id: !input 'remote'
- variables:
command: '{{ trigger.to_state.attributes.action }}'
- choose:
- conditions:
- '{{ command == ''on-press'' }}'
sequence: !input 'action_on-press'
- conditions:
- '{{ command == ''off-press'' }}'
sequence: !input 'action_off-press'
- conditions:
- '{{ command == ''up-press'' }}'
sequence: !input 'action_up-press'
- conditions:
- '{{ command == ''down-press'' }}'
sequence: !input 'action_down-press'
- conditions:
- '{{ command == ''on-hold'' }}'
sequence: !input 'action_on-hold'
- conditions:
- '{{ command == ''off-hold'' }}'
sequence: !input 'action_off-hold'
- conditions:
- '{{ command == ''up-hold'' }}'
sequence: !input 'action_up-hold'
- conditions:
- '{{ command == ''down-hold'' }}'
sequence: !input 'action_down-hold'
default: []
