This is a fork from Original version
The original works for the creator and will not be updated according to their comment.
Each button on the remote can be set to whatever action for both _press and _hold events.
The blueprint have been updated to:
- New mqtt payload using underscore (_) instead of dash (-).
- Defaults have been added to the inputs so that you don’t have to use them.
Verified to work with Philips Hue switch model #929002398602
Github gist
blueprint:
name: Zigbee2Mqtt Hue Dimmer Switch control v3
description: ''
domain: automation
input:
dimmer_action:
name: Dimmer MQTT topic
description: 'type in your Dimmer MQTT topic (i.e. zigbee2mqtt/Dimmer/action)'
selector:
text:
action_on_press:
description: select action to run when you press ON
default: []
selector:
action_off_press:
description: select action to run when you press OFF
default: []
selector:
action_up_press:
description: select action to run when you press UP
default: []
selector:
action_down_press:
description: select action to run when you press DOWN
default: []
selector:
action_on_hold:
description: select action to run when you hold ON
default: []
selector:
action_off_hold:
description: select action to run when you hold OFF
default: []
selector:
action_up_hold:
description: select action to run when you hold UP
default: []
selector:
action_down_hold:
description: select action to run when you hold DOWN
default: []
selector:
- platform: mqtt
topic: !input dimmer_action
payload: on_press
- platform: mqtt
payload: off_press
- platform: mqtt
payload: up_press
- platform: mqtt
payload: down_press
- platform: mqtt
payload: on_hold
- platform: mqtt
payload: off_hold
- platform: mqtt
payload: up_hold
- platform: mqtt
payload: down_hold
- choose:
- conditions:
- condition: trigger
sequence:
!input action_on_press
- conditions:
sequence:
!input action_off_press
- conditions:
sequence:
!input action_up_press
- conditions:
sequence:
!input action_down_press
- conditions:
sequence:
!input action_on_hold
- conditions:
sequence:
!input action_off_hold
- conditions:
sequence:
!input action_up_hold
- conditions:
sequence:
!input action_down_hold
default: []
mode: restart
