HA doesn’t detect my Hue bridge with the following error:
Error setting up entry sf-Hue for hue
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 215, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/hue/__init__.py", line 114, in async_setup_entry
allow_unreachable = config[CONF_ALLOW_UNREACHABLE]
KeyError: 'allow_unreachable'
Any hint or advice how to resolve that?
Been working for a very long time without issue…
All I have is this in my configuration file:
hue:
bridges:
- host: 192.168.1.30
Downgraded to 0.104.0 and it works now… there seems to be a bug in 0.104.1… I’ll wait for comments and will stay on this version for now…
Harry13
(George Georgas)
January 17, 2020, 2:43am
3
Open an issue so they can investigate
Found solution; you need to add the following config options to hue
hue:
bridges:
- host: xxx
allow_unreachable: true <- this
allow_hue_groups: true <- this
According to integration page, these are optional, so seems like a bug to me
Someone was faster than me, but I added the comment to github issue too.
opened 07:33AM - 17 Jan 20 UTC
closed 11:38PM - 17 Jan 20 UTC
Home Assistant release with the issue:
0.104.1
Last working Home Assistant release (if known):
0.104.0
Operating environment (Hass.io/Docker/Windows/etc.):
Ubuntu 18.4 LTS with Home Assistant 0.104.0 in...
integration: hue
haaghala
(Mikko Hakala)
January 17, 2020, 9:55am
6
I solved this by uninstalling HUE integration, reboot HA and re-install HUE. All lights etc. will show up just like before (no need to rename any entities)
yes! that worked for me as well, thank you so much!
