I’m using Home Assistant OS newest version with CC2652RB on a RPI 2and Philips Hue e27 bulbs.
When I ask Siri to change the color or when I change the color from the Apple Home app, then it changes the color without any transition effect.
How can I enable color change with a smooth transition ?
I was not able to navigate to root in FileEditor.
After setting enforce_basepath: false in the config tab of FileEditor, I was able to navigate to root and then to /share/zigbee2mqtt and edit the devices.yml file.
And now transition works fine
Thank you @m0wlheld!
