If you have a configured switch in the HUE app there is a “reset” below the line stating “Configure in Apple Home”. When I press this “reset” it show a new setup page. In the buttom of this page there is a “configure in another app”. Then you have a “not configured” switch in the HUE app
Just tested it:-) Hope the wife/kids will not enter the kitchen during the next 5 min:-)
…BINGO … so now i just have to instal the right blueprint and re config the 5 X4 clicks… Hope the family dont come home for another 3 hours or so … WAHA
Hmm i can se the buttons sends signal to HA but the action from the blueprint dont show. aka nothing happens. Tried with “room” and also with “entitet”
short release and press … still no light? What do i miss
ah well i have them both and none off them are working .
The error - simple noting happends .
The assigned light(s) stay off (or on- tried to toggle and Off) i can se the switch being pressed in the tracking, but some how it doesn’t affect the bulb …
also tried to hit “run” in the blueprint- and the light respond perfect. But pressing the button no respond…
Noob question !
How do you get the full picture of the trace ? im having the yaml in front -as shown i can mode the picture/trace behind but not se it all at once …
I can see your screeeshot is from the blueprint in post 69. Please use post1/32 for this to work. When we have that one working, then you can try the one in 69.
Well made a little test. Ilet the entry for the 4 bottons stay i HUE - and replicated them i in HA with a little extra bullb to se if the blueprint was on the job. Now it works.
After that, deleted the switch in HUE app - and it still works… SUCCES. Thanks for staying om the problem @khvej8 … Still have to se how i make a screen shot of the trace in a whole pic.
If i start with the switch with no actions in the HUE app / aka start with it in “controlled in another app” then the bluprint dont work.
If i have action i the hue app - then make action in AND THEN discard the actions in the HUE app/ turn it to be “controlled in another app” then it works.
So… make actions in the HUE app for al 4 buttons- then make same or different action i HA / Blueprint and the discard the actions in the HUE app…
Just tested again - it will not trigger the action if there are no actions in HUE …
I have been using the blueprint for a few months now, but since today, dimming and brightening the lights no longer works. This problem occurs on all 4 buttons (2 switches). Anyone have an idea what’s going wrong?
Have you upgraded to 2024.07?
I do not use the blueprint anymore, as I have moved the switches to Zigbee2MQTT, however moved one back to test.
The Hue_event still shows a “repeat”, however the automation using the variable will get a initial_press value with the same timestamp. These should be the same and was earlier.
Have you tired to move to 2024.06.xx. If it works, then it is a Hue integration problem. Needs to be reported to the Hue integration developers.
There is currently an error, probably started by 2024.07 or 2024.06. As the repeat and long_release is not triggerede correctly in the integration, the blueprint is not working
The initial_press and short_release are working. Be aware that if you make a long press it will result in several “initial_press” commands.
