Philips Hue integration switching one light by itself
the title says it all. This often happens 3 or 4 times in a row when I turn off the light manually.
I have not created any automation, and it’s not a problem by Hue itself, because when I deactivate the integration the system works like expected.
Also problems with the bridge can be ruled out because I just switched the bridge to the new Pro. (And yes, I know that I could use Zigbee2MQTT instead ;))
Any help would be appreciated.
