Philips Hue Light - Factory Reset - Fails
I’m having an issue with a Philips Hue bulb that can’t be reset to factory defaults.
The light is already linked to a ZigBee network on controller 1 using deCONZ. I tried to factory reset the light but this raises an UNSUP_CLUSTER_COMMAND error:
Option 2 is to run the off-on-off-on-off-on … thing 5 times with 8 seconds on and 2 seconds off, but the light never blinks to indicate it is in pairing mode. I suspect the reason is that the controller 1 is still active (can’t deactivate it because it still has plenty of devices attached) so during the 8 seconds it is ON, the light joins the old network again (even if I delete the node from the deCONZ network).
This is getting me crazy. Do I really need to go to another house out of the controller 1 network to factory reset the bulb?
Once reset, the bulb will be joined to the new controller network, but that step I can’t initiate until the bulb is reset.
Do you have any ideas about what to do?
I’ll try to:
  1. Delete the bulb from controller 1 (deconz)
  2. Restart controller 1 (to make sure the node is discarded on the network).
  3. Start the reset procedure again and see what happens.
I did already this without the step 2
For the records,
Even restarting controller 1 after node delete the bulb still doesn’t reset itself. If I enable pairing on controller 1 again, even without reseting the bulb (which is what I can’t do) the bulb joins again controller 1 network.
Do you have a remote? You can reset with that.
Hi, Thanks for answering.
No I don’t have a remote. I know the bulb has bluetooth access but never used it nor installed original Philips bluetooth controllers. It looks like I need to create an account to do that so I uninstalled that app from my phone.
I’ve actually found current firmware version is 1.55.8_r28815
I’ve also found there is an updated version. I’m now using OTA over controller 1 network to update firmware. Maybe I can run the reset command once it is updated.
I don’t think the on-off thing works any more - if it ever did.
Do you have a Hue dimmer switch? If so…
  • Make sure the bulb is turned on
  • Hold the dimmer switch close to it
  • Press and hold the top and bottom buttons on the switch together
After 5-10 seconds the bulb should flash, indicating that it’s in pairing mode.
Edit: Sorry - @fleskefjes suggested this while I was typing… The dimmer switch/remote needs to be Zigbee.
I have some Hue On/Off switch (single button) I don’t have any dimmer switch :frowning:
Buy a dimmer or borrow from a friend? It’s handy to have as you’ve noticed and you could of course use it with deconz too.
yep! I’ve just purchased one. It should arrive tomorrow
FYI, there are a few different workaround tips for how to manually factory reset Philips Hue devices posted here → https://www.home-assistant.io/integrations/zha#add-philips-hue-bulbs-that-have-previously-been-added-to-another-bridge
Hi, I managed to reset the bulb this morning. The problem was that the description of the off-on-off process was wrong. The right process is:
Start from ON
Turn OFF, wait 5 seconds
Turn ON, wait 10 seconds
Turn OFF, wait 10 seconds
The bulb blinks!
I was going crazy, then I found this solution, I love you, thank you! :smiling_face_with_tear:
I know this is an old thread, but none of the methods here worked for me. I found this video that worked perfectly, using Alexa Echo device to factory reset the bulb.
Once it was reset, I deleted if from Alexa, it it was almost immediatly picked up by Home Assistant via Zigbee.
unfortunately didn’t work for me :frowning:
This worked, interestingly enough I’ve done this process right before a firmware update aswell and then the lights went into pairing on the first attempt of of this power cycle routine https://www.youtube.com/watch?v=qvCS1BIM8EY&t=410s
just wanted to confirm that this works (after some trial and error), thank you!
Just adding that this worked for me with one nuance, I was trying to reset some ceiling pendants with multiple (2 or 3) bulbs in the same fixture. I couldn’t get it to reliably work until I unscrewed all but one of the bulbs, just enough to not get power, such that I was resetting one bulb at a time.
Also, I found that I needed to hold down the buttons on the dimmer switch until the app had discovered the bulb and added it to a room. If I let go of the buttons too early, the bulbs seemed to quickly leave pairing mode, going from bright white (pairing mode) to the default warm white (not pairing mode).
