I’m using Z2M with Philips Hue Lamps.
The Coordinator is in basement.
The First “Lamp” in ground floor is a Philips Hue Lightstrip and has good connection to the coordinator.
Then there are 3 Outdoor Lamps from Philips Hue.
Its not possible to get a stable connection for the outdoor lamps to the coordinator.
Only 1 Outdoor Lamp has “OK” connection to the Coordinator.
I only can get a connection over the Lightstrip which is also a router device with the outdoor lamps.
So I have to pair the Outdoor Lamps directly in Z2M to the Lightstripe and its working.
If I power down the Lightstripe, I have the expectation that the Outdoor Lamps connect to the One Lamp, that has good connection to the coordinator.
But they dont.
No connection anymore without the Lightstripe.
When I pair all the Lamps with Zigbee Pairing option “all”, All Lamps appear in Z2M, but I can’t control the outdoor Lamps, because of the range to the coordinator.
Any ideas ?
