Philips Hue Motions Sensor SML003 not working
Hey there - i got a new Philips Motion Sensor.
( I do have 2 * SML001 and they are working perfectly )
I am able to add the SML003 Sensor - and it is working for maybe 1 oder 2 minutes. Then it stops reporting back lux and motion values.
If i’ll do reconfigure device - it also failes.
I readded the device more than 3 times now.
Here are the diagnostic informations - anything i could do?
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2023.11.2",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.11.6",
    "docker": true,
    "arch": "aarch64",
    "timezone": "Europe/Berlin",
    "os_name": "Linux",
    "os_version": "6.1.21-v8",
    "supervisor": "2023.11.3",
    "host_os": "Home Assistant OS 11.1",
    "docker_version": "24.0.6",
    "chassis": "embedded",
    "run_as_root": true
  "custom_components": {},
  "integration_manifest": {
    "domain": "zha",
    "name": "Zigbee Home Automation",
    "after_dependencies": [
      "onboarding",
      "usb"
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly"
    "config_flow": true,
    "dependencies": [
      "file_upload"
    "documentation": "https://www.home-assistant.io/integrations/zha",
    "iot_class": "local_polling",
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp",
      "universal_silabs_flasher"
    "requirements": [
      "bellows==0.36.8",
      "pyserial==3.5",
      "pyserial-asyncio==0.6",
      "zha-quirks==0.0.106",
      "zigpy-deconz==0.21.1",
      "zigpy==0.59.0",
      "zigpy-xbee==0.19.0",
      "zigpy-zigate==0.11.0",
      "zigpy-znp==0.11.6",
      "universal-silabs-flasher==0.0.14",
      "pyserial-asyncio-fast==0.11"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "description": "*2652*",
        "known_devices": [
          "slae.sh cc2652rb stick"
        "vid": "1A86",
        "pid": "55D4",
        "description": "*sonoff*plus*",
        "known_devices": [
          "sonoff zigbee dongle plus v2"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "sonoff zigbee dongle plus"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*tubeszb*",
        "known_devices": [
          "TubesZB Coordinator"
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "description": "*zigstar*",
        "known_devices": [
          "ZigStar Coordinators"
        "vid": "1CF1",
        "pid": "0030",
        "description": "*conbee*",
        "known_devices": [
          "Conbee II"
        "vid": "10C4",
        "pid": "8A2A",
        "description": "*zigbee*",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "description": "*zigate*",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "description": "*bv 2010/10*",
        "known_devices": [
          "Bitron Video AV2010/10"
    "zeroconf": [
        "type": "_esphomelib._tcp.local.",
        "name": "tube*"
        "type": "_zigate-zigbee-gateway._tcp.local.",
        "name": "*zigate*"
        "type": "_zigstar_gw._tcp.local.",
        "name": "*zigstar*"
        "type": "_uzg-01._tcp.local.",
        "name": "uzg-01*"
        "type": "_slzb-06._tcp.local.",
        "name": "slzb-06*"
    "is_built_in": true
  "data": {
    "ieee": "**REDACTED**",
    "nwk": 53464,
    "manufacturer": "Signify Netherlands B.V.",
    "model": "SML003",
    "name": "Signify Netherlands B.V. SML003",
    "quirk_applied": true,
    "quirk_class": "zhaquirks.philips.motion.SignifyMotion",
    "quirk_id": null,
    "manufacturer_code": 4107,
    "power_source": "Battery or Unknown",
    "lqi": 255,
    "rssi": -64,
    "last_seen": "2023-11-19T15:09:28",
    "available": true,
    "device_type": "EndDevice",
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4107, maximum_buffer_size=82, maximum_incoming_transfer_size=128, server_mask=11264, maximum_outgoing_transfer_size=128, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
      "endpoints": {
        "2": {
          "profile_id": "0x0104",
          "device_type": "0x0107",
          "input_clusters": [
            "0x0000",
            "0x0001",
            "0x0003",
            "0x0400",
            "0x0402",
            "0x0406"
          "output_clusters": [
            "0x0000",
            "0x0003",
            "0x0006",
            "0x0019"
      "model": "SML003"
    "active_coordinator": false,
    "entities": [
        "entity_id": "sensor.flur_bewegung_mitte_batterie",
        "entity_id": "binary_sensor.flur_bewegung_mitte_belegung",
        "entity_id": "sensor.flur_bewegung_mitte_beleuchtungsstarke",
        "entity_id": "select.flur_bewegung_mitte_bewegungsempfindlichkeit",
        "entity_id": "button.flur_bewegung_mitte_identifizieren",
        "entity_id": "switch.flur_bewegung_mitte_led_ausloseanzeige",
        "entity_id": "binary_sensor.flur_bewegung_mitte_offnet",
        "entity_id": "sensor.flur_bewegung_mitte_temperatur",
    "neighbors": [],
    "routes": [],
    "endpoint_names": [
        "name": "OCCUPANCY_SENSOR"
    "user_given_name": "Flur Bewegung Mitte",
    "device_reg_id": "d5aff74881c4f9003e75cfa05c207a36",
    "area_id": null,
    "cluster_details": {
      "2": {
        "device_type": {
          "name": "OCCUPANCY_SENSOR",
          "id": 263
        "profile_id": 260,
        "in_clusters": {
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {
              "0x0033": {
                "attribute_name": "trigger_indicator",
                "value": 0
            "unsupported_attributes": {}
          "0x0001": {
            "endpoint_attribute": "power",
            "attributes": {
              "0x0021": {
                "attribute_name": "battery_percentage_remaining",
                "value": 200
              "0x0020": {
                "attribute_name": "battery_voltage",
                "value": 30
              "0x0031": {
                "attribute_name": "battery_size"
              "0x0033": {
                "attribute_name": "battery_quantity"
          "0x0003": {
            "endpoint_attribute": "identify",
            "attributes": {},
          "0x0400": {
            "endpoint_attribute": "illuminance",
            "attributes": {
              "0x0000": {
                "attribute_name": "measured_value",
                "value": 5039
          "0x0402": {
            "endpoint_attribute": "temperature",
            "attributes": {
              "0x0000": {
                "value": 2384
          "0x0406": {
            "endpoint_attribute": "philips_occupancy",
            "attributes": {
              "0x0000": {
                "attribute_name": "occupancy",
                "value": 0
              "0x0030": {
                "attribute_name": "sensitivity",
                "value": 2
        "out_clusters": {
          "0x0000": {
            "attributes": {},
          "0x0003": {
            "attributes": {},
          "0x0006": {
            "endpoint_attribute": "on_off",
            "attributes": {
              "0x0000": {
                "attribute_name": "on_off",
                "value": 0
              "0x0000": {
              "0x4003": {
                "attribute_name": "start_up_on_off"
          "0x0019": {
            "endpoint_attribute": "ota",
            "attributes": {},
Have you checked on GitHub?
There’s only this open:
Indeed the same for my SML001 - but it is not a big deal.
Nothing about my SML003 problem.
If you search for motion - there are many bugs :-/
Are there any “bullet proof” zigbee zha motion sensors with lux sensors?
Hi, I think I have the same issue: I also a have the SML003 and it is giving readings so it is working. The motion detection works just once and than no more.
Did you ever find a solution ? I am thinking to update the firmware but just need to find a Hue bridge first.
No solution yet - trying other sensors now / aqara motion p1.
Not sure if this is a firmware thing - but would be great if you get it working.
