Philips Hue PIR sometimes does not update
I have multiple Philips Hue PIR in my apartment connected to HA. It works like intended but sometimes the entity does not update from movement to nothing. So in entity graph I see a long movement until somebody triggers the PIR again and then it updates to not moving. I hope it is clear :grin:.
Can somebody please help me with troubleshooting this?
I am using latest HA in latest Hassio on RPi4.
Philips Hue Motion detector takes 10s to go back to “no movement”, for me, if that’s what you mean.
Whats your Zigbee signal strength/coverage like?
I have mine connected through Z2M and a 2652 stick and the Hue motion sensors have been rock solid for me.
Yeah, I know about the small timeout, that’s OK. I am talking about not receiving “no movement” sometimes over whole night or until next “movement” and “no movement” pair received.
I have mine paired to the original HUE gateway. It is couple of meters in small appartment and I know that the “no movement” is received by the gateway because I have an automation to turn on the light after some time of “no movement” state right in the gateway. But the HA is not seeing this state sometimes.
The new Hue integration, introduced in version 2031.12.0, has had several problems that the integration’s developer continues to correct in each patch release. If you are using 2021.12.3 and are experiencing this problem, please report it as an Issue in the Core repository on GitHub. Provide the developer with as much information as you have available concerning the problem.
Thank you very much for this info. I have .2 but will upgrade .3 today and will report info to that Github issue.
Have a nice day!
