Philips Hue Remote Buttons - Using ZHA Integration
Hue Remote Mapper
What does this automation do…
This is mapper automation, that allows you to attach actions to the hue remote. All four buttons (On, Dim Up, Dim Down, Off), and all six states (single/double/triple/quadrupal/quintuple/long press). You can attach any event you want, not just lights. I’ve friends that use these remotes for launching Netflix/Disney+ on their tv, etc.
Why did I make this…
I realised that there is no easy way in hassio to map button presses on zigbee remotes to actions. It originally started, as you’d expect, mapping button pushes to lights coming on to specific light levels. As my knowledge of blueprints improved, I realised that I could just add actions, any make it just a single universal blueprint.
I’ve made a number of automations, but this is the first that I’ve published here. So please be kind. I’m aware it’s not the most efficient, so if you can recommend any optimisations, that would be fantastic, thank you.
Get started
Click the badge to import this Blueprint:
Or import this Blueprint by using the forum topic URL:
blueprint:
  name: Hue Remote Mapper (ZHA Integration)
  description: |
    A remote control mapper for the Philips Hue Remotes (RWL020, RWL021, and RWL022).
  domain: automation
  source_url: https://gist.github.com/manix84/7c9cccac1f498b6b0fa134054f86ecab
  author: Manix84
  input:
    dimmer_device_id:
      name: Dimmer Remote Device
      description: "Your Hue dimmer remote (e.g. RWL020, RWL021, RWL022); check Hue integration and/or Hue app if you don't know the name"
      selector:
        device:
          filter:
            - integration: zha
              manufacturer: "Philips"
              model: RWL020
            - integration: zha
              model: RWL021
            - integration: zha
              model: RWL022
    button1_actions:
      icon: mdi:numeric-1-box-outline
      collapsed: true
      input:
        btn_on_single_press_action:
          name: Single Press Actions
          description: <ha-icon icon="mdi:numeric-1-box"></ha-icon> Actions to run, when button is pressed quickly.
          default: []
          selector:
            action: {}
        btn_on_double_press_action:
          name: Double (2) Press Actions
          description: <ha-icon icon="mdi:numeric-2-box-multiple"></ha-icon> Actions to run, when button is pressed quickly twice.
          default: []
          selector:
            action: {}
        btn_on_triple_press_action:
          name: Triple (3) Press Actions
          description: <ha-icon icon="mdi:numeric-3-box-multiple"></ha-icon> Actions to run, when button is pressed quickly three times.
          default: []
          selector:
            action: {}
        btn_on_quadruple_press_action:
          name: Quadruple (4) Press Actions
          description: <ha-icon icon="mdi:numeric-4-box-multiple"></ha-icon> Actions to run, when button is pressed quickly four times.
          default: []
          selector:
            action: {}
        btn_on_quintuple_press_action:
          name: Quintuple (5) Press Actions
          description: <ha-icon icon="mdi:numeric-5-box-multiple"></ha-icon> Actions to run, when button is pressed quickly five times.
          default: []
          selector:
            action: {}
        btn_on_long_press_action:
          name: Long Press Actions
          description: <ha-icon icon="mdi:checkbox-multiple-blank"></ha-icon> Actions to run, when button is pressed and released after over a second.
          default: []
          selector:
            action: {}
    button2_actions:
      name: Dim Up Button
      icon: mdi:chevron-up-box-outline
      collapsed: true
      input:
        btn_up_single_press_action:
          default: []
          selector:
            action: {}
        btn_up_double_press_action:
          default: []
          selector:
            action: {}
        btn_up_triple_press_action:
          default: []
          selector:
            action: {}
        btn_up_quadruple_press_action:
          default: []
          selector:
            action: {}
        btn_up_quintuple_press_action:
          default: []
          selector:
            action: {}
        btn_up_long_press_action:
          default: []
          selector:
            action: {}
    button3_actions:
      name: Dim Down Button
      icon: mdi:chevron-down-box-outline
      collapsed: true
      input:
        btn_down_single_press_action:
          default: []
          selector:
            action: {}
        btn_down_double_press_action:
          default: []
          selector:
            action: {}
        btn_down_triple_press_action:
          default: []
          selector:
            action: {}
        btn_down_quadruple_press_action:
          default: []
          selector:
            action: {}
        btn_down_quintuple_press_action:
          default: []
          selector:
            action: {}
        btn_down_long_press_action:
          default: []
          selector:
            action: {}
    button4_actions:
      icon: mdi:numeric-0-box-outline
      collapsed: true
      input:
        btn_off_single_press_action:
          default: []
          selector:
            action: {}
        btn_off_double_press_action:
          default: []
          selector:
            action: {}
        btn_off_triple_press_action:
          default: []
          selector:
            action: {}
        btn_off_quadruple_press_action:
          default: []
          selector:
            action: {}
        btn_off_quintuple_press_action:
          default: []
          selector:
            action: {}
        btn_off_long_press_action:
          default: []
          selector:
            action: {}
description: ""
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input dimmer_device_id
      command: on_press
  - platform: event
    event_data:
      command: on_double_press
  - platform: event
    event_data:
      command: on_triple_press
  - platform: event
    event_data:
      command: on_quadruple_press
  - platform: event
    event_data:
      command: on_quintuple_press
  - platform: event
    event_data:
      command: on_long_release
  - platform: event
    event_data:
      command: up_press
  - platform: event
    event_data:
      command: up_double_press
  - platform: event
    event_data:
      command: up_triple_press
  - platform: event
    event_data:
      command: up_quadruple_press
  - platform: event
    event_data:
      command: up_quintuple_press
  - platform: event
    event_data:
      command: up_long_release
  - platform: event
    event_data:
      command: down_press
  - platform: event
    event_data:
      command: down_double_press
  - platform: event
    event_data:
      command: down_triple_press
  - platform: event
    event_data:
      command: down_quadruple_press
  - platform: event
    event_data:
      command: down_quintuple_press
  - platform: event
    event_data:
      command: down_long_release
  - platform: event
    event_data:
      command: off_press
  - platform: event
    event_data:
      command: off_double_press
  - platform: event
    event_data:
      command: off_triple_press
  - platform: event
    event_data:
      command: off_quadruple_press
  - platform: event
    event_data:
      command: off_quintuple_press
  - platform: event
    event_data:
      command: off_long_release
condition: []
  - choose:
      - alias: On Button - Single Press
        conditions:
          - condition: trigger
        sequence: !input btn_on_single_press_action
      - alias: On Button - Double Press
        conditions:
        sequence: !input btn_on_double_press_action
      - alias: On Button - Triple Press
        conditions:
        sequence: !input btn_on_triple_press_action
      - alias: On Button - Quadruple Press
        conditions:
        sequence: !input btn_on_quadruple_press_action
      - alias: On Button - Quintuple Press
        conditions:
        sequence: !input btn_on_quintuple_press_action
      - alias: On Button - Long Press
        conditions:
        sequence: !input btn_on_long_press_action
      - alias: Dim Up Button - Single Press
        conditions:
        sequence: !input btn_up_single_press_action
      - alias: Dim Up Button - Double Press
        conditions:
        sequence: !input btn_up_double_press_action
      - alias: Dim Up Button - Triple Press
        conditions:
        sequence: !input btn_up_triple_press_action
      - alias: Dim Up Button - Quadruple Press
        conditions:
        sequence: !input btn_up_quadruple_press_action
      - alias: Dim Up Button - Quintuple Press
        conditions:
        sequence: !input btn_up_quintuple_press_action
      - alias: Dim Up Button - Long Press
        conditions:
        sequence: !input btn_up_long_press_action
      - alias: Dim Down Button - Single Press
        conditions:
        sequence: !input btn_down_single_press_action
      - alias: Dim Down Button - Double Press
        conditions:
        sequence: !input btn_down_double_press_action
      - alias: Dim Down Button - Triple Press
        conditions:
        sequence: !input btn_down_triple_press_action
      - alias: Dim Down Button - Quadruple Press
        conditions:
        sequence: !input btn_down_quadruple_press_action
      - alias: Dim Down Button - Quintuple Press
        conditions:
        sequence: !input btn_down_quintuple_press_action
      - alias: Dim Down Button - Long Press
        conditions:
        sequence: !input btn_down_long_press_action
      - alias: Off Button - Single Press
        conditions:
        sequence: !input btn_off_single_press_action
      - alias: Off Button - Double Press
        conditions:
        sequence: !input btn_off_double_press_action
      - alias: Off Button - Triple Press
        conditions:
        sequence: !input btn_off_triple_press_action
      - alias: Off Button - Quadruple Press
        conditions:
        sequence: !input btn_off_quadruple_press_action
      - alias: Off Button - Quintuple Press
        conditions:
        sequence: !input btn_off_quintuple_press_action
      - alias: Off Button - Long Press
        conditions:
        sequence: !input btn_off_long_press_action
    default:
      - service: persistent_notification.create
          message: >-
            Hue dimmer ran default event from "choose" action on button press!
            Please check any automations which may not be handling this event: {{ trigger.id }}
          notification_id: hue-remote-lights
          title: >-
            Uncaught Dimmer Command ({{ trigger.id }})
mode: single
I’d love some feedback. Is this a bad blueprint? Is it just tough to understand what it does? Should I give up making blueprints all-together? Any feedback would be helpful.
I mean for the HUE Remotes there a lots of blueprints around for remap the Buttons To-Do different actions.
In the past i used this one:
But i will give your blueprint a try in the next Day.
This honestly looks awesome and -super- simple to setup. Unfortunately i’m not using ZHA and on zigbee2mqtt! :cry:
Thanks for the kind words. I do have a variant for Philips Hue hub. I’m sure it would be easy to convert it to support zigbee2mqtt, but I’ve never used it before, so I couldn’t test it.
I’d no idea their were so many of these out there. I went looking a while ago, and didn’t see any, so thought my idea was relatively unique.
Hi Rob,
This is one of the better blueprints for this that I’ve found - thank you.
Would really appreciate the option to repeat a command when held to dim lights for example.
Hi All, if it won’t find the device during set up., change the Yaml code in the config files under blueprints, and replace
"manufacturer: “Phillips”
→ with
"manufacturer: “Signify Netherlands B.V”
You can check in the ZHA profile if it shows Phillips or something else:
See Philips Lighting is now Signify | Signify Company Website
My device does show the manufacturer as “Signify Netherlands B.V” but none of my Hue buttons show up as available for this blueprint.
