Philips hue remove ungrouped lights
As you see below i got all my hue lights but also all my hue groups, i can i hide the lights?
I take it that is on your default view?
You can either create a group that only contains the lights you want to display and then display that group in your default view. More info here: https://home-assistant.io/components/group/
Or you can just “hide” the lights in the customize section at the top of your config file:
homeassistant:
  customize:
    light.your_light
      hidden: true
