I have a Hue motion sensor triggering a nightlight:
- alias: Night light on landing #if motion is detected
initial_state: on
platform: state
entity_id: sensor.motion_sensor_upstairs_landing
to: 'on'
service: homeassistant.turn_on
entity_id: light.gateway_light
brightness: 170
rgb_color: [255,103,23]
You wouldn’t need the data block for a swtich.
You could try changing “True” to “On”. I don’t think it matters but you could also maybe use homeassistant.turn_on rather than switch.turn_on?
Thanks, the ‘on’ bit worked as per below. My next question is regarding the delay, is there a way to reset the countdown timer? Ie. The motion sensor is sensing movement every 30 seconds, therefore, the delay below gets reset.?
- id: '1540721538342'
alias: New Automation
- entity_id: sensor.downstairs_study_motion_sensor
platform: state
to: 'on'
- data: {}
entity_id: switch.outside_light
service: switch.turn_on
- delay: 00:01:00
- entity_id: switch.outside_light
service: switch.turn_off
