I am using Philips hue in my Home Assistant setup. I have 10 bulbs. In my home assistant UI shows them all as “on-off” switches. Works perfectly. But my kid loves to set some terrible colors and my automation system auto turns them off at night.
The day after, when I use the switches in my UI it turns on as the last used color… And then I have to manually go in and change to a “normal” color.
Is there a way to set a specific color, brightness etc. when I turn the switch on? I mange to do this when running automations, but not when I only want to use the on-off switches.
