Philips Hue Tap Dial - Custom Actions and Dimming - ZHA
Control lighting with a Philips Hue Tap Dial (RDM002) connected via ZHA.
  • Run custom actions with any of the four buttons (single click)
  • Control the brightness of light(s) with the dial, based on the last button used
A combination of the dimming functionality from the blueprint by @apollo1220, and the custom button actions from the blueprint by @vnkr.
blueprint:
    name: Philips Hue Tap Dial Switch for Lighting
    description: Control lights with a Philips Hue Tap Dial (RDM002) connected via ZHA. Run custom lighting actions with the four buttons, and dim the most recently used light(s) using the dial.
    domain: automation
    input:
        remote:
            name: Philips Hue Tap Dial Device
            description: Choose the device to use for this automation
            selector:
                device:
                    integration: zha
                    manufacturer: Signify Netherlands B.V.
                    model: RDM002
                    multiple: false
        button_1:
            name: Button 1 Press
            description: Choose the action(s) to run after pressing button 1
            selector:
                action: {}
        dim_1:
            name: Button 1 Dimming
            description: Choose the light(s) to dim after pressing button 1
            selector:
                    entity: {}
        button_2:
            name: Button 2 Press
            description: Choose the action(s) to run after pressing button 2
            selector:
                action: {}
        dim_2:
            name: Button 2 Dimming
            description: Choose the light(s) to dim after pressing button 2
            selector:
                    entity: {}
        button_3:
            name: Button 3 Press
            description: Choose the action(s) to run after pressing button 3
            selector:
                action: {}
        dim_3:
            name: Button 3 Dimming
            description: Choose the light(s) to dim after pressing button 3
            selector:
                    entity: {}
        button_4:
            name: Button 4 Press
            description: Choose the action(s) to run after pressing button 4
            selector:
                action: {}
        dim_4:
            name: Button 4 Dimming
            description: Choose the light(s) to dim after pressing button 4
            selector:
                    entity: {}
        current_light:
            description: Select a Text Helper to track the current light(s) to dim
            selector:
                entity:
                    domain: input_text
        dim_scale:
            description: Set the scale factor for dimming. A lower number will result in more gradual dimming, while a larger number will result in faster dimming.
            default: 1.0
            selector:
                number:
                    min: 0.0
                    max: 5.0
                    step: 0.01
mode: restart
max_exceeded: silent
variables:
    dim_1: !input dim_1
    dim_2: !input dim_2
    dim_3: !input dim_3
    dim_4: !input dim_4
    current_light: !input current_light
    dim_scale: !input dim_scale
    lights:
        dim_1: !input dim_1
        dim_2: !input dim_2
        dim_3: !input dim_3
        dim_4: !input dim_4
    event: '{{ trigger.event.data.command }}'
    args: '{% if (trigger.event.data.args is defined) %}{{trigger.event.data.args}}{% endif %}'
    params: '{% if (trigger.event.data.params is defined) %}{{trigger.event.data.params}}{% endif %}'
    step_size: '{% if (trigger.event.data.params is defined) and (trigger.event.data.params.step_size is defined) %}{{trigger.event.data.params.step_size}}{% endif %}'
    step_mode: '{% if (trigger.event.data.params is defined) and (trigger.event.data.params.step_mode is defined) %}{{trigger.event.data.params.step_mode}}{% endif %}'
    scene: "{{ trigger.event.data.args[1] }}"
  - platform: event
    event_type: zha_event
    event_data:
        device_id: !input remote
  - choose:
    # Buttons
      - conditions:
          - '{{ event == "recall" }}'
          - '{{ scene == 1 }}'
        sequence: !input button_1
      - conditions:
          - '{{ scene == 0 }}'
        sequence: !input button_2
      - conditions:
          - '{{ scene == 5 }}'
        sequence: !input button_3
      - conditions:
          - '{{ scene == 4 }}'
        sequence: !input button_4
    # Dimming
      - conditions:
          - "{{ event == 'step_with_on_off' }}"
          - "{{ step_mode == 'StepMode.Up' }}"
        sequence:
          - service: light.turn_on
            target: "{{ lights[states(current_light)] }}"
                brightness_step_pct: "{{ step_size * dim_scale }}"
                transition: 1
      - conditions:
          - "{{ step_mode == 'StepMode.Down' }}"
        sequence:
                brightness_step_pct: "{{ -step_size * dim_scale }}"
                transition: 1
  - choose:
    # Last used light state
      - conditions:
        sequence:
          - service: input_text.set_value
                entity_id: !input "current_light"
                value: dim_1
      - conditions:
        sequence:
                value: dim_2
      - conditions:
        sequence:
                value: dim_3
      - conditions:
        sequence:
                value: dim_4
