Do you need BOTH
hue:
bridges:
- host: BRIDGE1_IP_ADDRESS
filename: phue.conf
and
light:
- platform: hue
host: DEVICE_IP_ADDRES
or just hue: ?
Do you need BOTH
hue:
bridges:
filename: phue.conf
and
light:
- platform: hue
or just hue: ?
I put first and receive this error
2017-12-21 11:40:41 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform hue
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py”, line 171, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/config/custom_components/sensor/hue.py”, line 25, in setup_platform
url = hass.data[DOMAIN] + ‘/sensors’
KeyError: ‘hue’
I took out everything, now I have no errors but the philips hue bridge is not discovered by HASSIO … options?
I am on 0.60 and the philips hue bridge is not discovered
