Philips Hue Water Damaged Bridge - How to Remove
Just thought i would make a quick post here to hopefully help others out. Last night i left a Windows open during a storm, and my Hue Bridge became Water Logged and Fried Itself. Unfortunately there is now much advice out there about how to replace a bridge with a new one. I was trying to avoid having to redo everything all 20lights etc… in the end i gave up and did it all manually. It was time for a tidy up anyway.
This assumes that the old bridge is completely Unresponsive. There are better ways to do this if your bridge can boot.
  1. Get your new Hue Bridge
  2. Add it to the Hue App
  3. Make a List of all your Hue Lights and there Serial Numbers
  4. Search for New Lights and Add each serial number (you can add them all at once)
  5. Allow the App to add the lights
  6. Rename as Appropriate
  7. Delete the App and Re-Install (Yes - The Bridge details are stored in the App, So once deleted it is gone for good.
  8. Now i’m readding the Hue Intergation to Home Assistant and having a good spring clean while i’m here.
